#11
You were talking about cast pulleys? I was talking about the stamped steel ones cracking. Sorry if I misled you.
...................... John Brown This isn't rocket surgery..... |
#12
Yes, the part number I posted is for 1967-68 3 groove cast pulleys used with short water pump configuration. As far as I can come up with from research, they will work for 1965-66 also, but not correct part number.
#13
I didn't know you were talking about a cast pulley. Maybe you could use a billet aluminum pulley and paint it cast iron gray. Mine is stamped steel. I have access to lots of CNC equipment so I might make a plate to go inside mine.
#14
![]() Quote:
I found a billet pulley on-line last night in Black, but it doesn't seem to exist anymore. I should call the manufacturer and ask.
#15
Well you all scared me enough to do something about it.
The Following 4 Users Say Thank You to big gear head For This Useful Post: | ||
#16
Very nice, Freddie. Maybe you can market that...
#17
Save your dust up and get an oem one....the gm pieces are not much more than the repo unlike the 291ab
Ebay Auctions http://www.ebay.com/sch/427-king/m.h...=16&_rdc=1 No Fisher priced toys here |
#18
3869978 is the correct original part number for all 65 Z16's (which all had PS), for all 66 L78's (regardless of whether the car had PS or not - if the car doesn't have PS then the third groove is just empty - don't ask me why they didn't use a 2-groove pulley), and for 67 L78's with PS.
Jeff Helms 65 Z16 Survivor 65 Z16 drag car 66 Chevelle L78 unrestored 67 Chevelle L78 unrestored 67 Camaro SS350 Survivor |
#19
Had exactly the same situation. Can't understand the disclaimer considering the original application is for 425 and 450hp cars, although looking the other posts seems to answer that question. I ended up getting the same pulley from Heartbeat.....without the disclaimer. There appears to be Chinesium and American made versions available but identical in appearance. I do have an original but it looks like it has been repaired as per the descriptions above regarding durability, so I opted not to use it.
Sounds like there is an opportunity for someone to offer a more suitable product. In the meantime, won't be revving my 427 L72 to 7K rpm |
#20
I see I never followed up on this. I did call the manufacturer/distributor and the grooves are standard depth, so mostly a stock replacement, or dress up part.
Mitch 1970 Chevelle SS 1966 Chevelle SS 1967 Camaro ss/rs 1938 Business coupe, street rod 2000 FXSTS, original owner, 13k miles Last edited by Too Many Projects; 07-28-2023 at 01:46 PM. |
Thread Tools | |
Display Modes | |
