Old 11-21-2020, 12:12 PM
L78_Nova (11-23-2020), markinnaples (11-23-2020)
  #18042
  #18043
  #18044
Old 11-21-2020, 01:21 PM
Excuse my ignorance. Never had a Chevelle with Cowl Induction.
Why are all the cowl flaps in the open position when parked? On the 69 Z/28, they only open when you floor it. Are the Chevelle flappers open by default?
Lee Stewart (11-21-2020)
  #18045
Old 11-21-2020, 01:39 PM
earntaz earntaz is offline
They are vacuum actuated -- when car is parked and engine off, there is no vacuum so they are open. When engine is started, vacuum pulls em' shut. During WOT vacuum is minimal and the cowls flaps open for cool air.
The Following User Says Thank You to earntaz For This Useful Post:
  #18046
Old 11-21-2020, 01:41 PM
PA tail code A/OA-10A…111 FW, Willow Grove ARS, PA, ANG/ACC
Old 11-21-2020, 01:43 PM
FT tail code A/OA-10A, HC-130P, HH-60G, A-10C…74th FG “Flying Tigers”, 75th FG “Tiger Sharks”, 23 Wg, Moody AFB, Ga
Old 11-21-2020, 01:46 PM
LN tail code F-100D/F, F-4D, F-15C/D/E, F-111F, HH-60G…492nd “Bolar Madhatters”,493rd “Grim Reapers”, 494th “Black Panthers” , 48 FW (USAFE), RAF Lakenheath, UK
Old 11-21-2020, 03:53 PM
SS427's Avatar
SS427 SS427 is offline
P63 and P39
Rick Nelson
The Following 2 Users Say Thank You to SS427 For This Useful Post:
earntaz (11-22-2020), Lee Stewart (11-21-2020)
  #18050
Old 11-21-2020, 05:08 PM
by Lynn:Excuse my ignorance.Never had a Chevelle with Cowl Induction.
By earntaz:They are vacuum actuated -- when car is parked and engine off, there is no vacuum so they are open. When engine is started, vacuum pulls em' shut. During WOT vacuum is minimal and the cowls flaps open for cool air.
Plus there's a 2nd door inside the 1970-72 Chevelle Cowl Ind. Hood that opens electrically also to keep crap out when off,so it's system uses 2 doors,the Camaro only uses one.
Both the Camaro & the Chevelle use this same inner electrical door set up.
The Camaro doesn't have the outside Vacuum operated door.
The Following 2 Users Say Thank You to Mr70 For This Useful Post:
