Old 09-17-2020, 10:46 PM
Enoch Enoch is offline
Very nice very hard to find weatherhead stamped brake line mounting clips. $60 for the pair. Ppff
************SOLD************
Old 09-17-2020, 11:27 PM
67 68 69 Camaro and Firebird power brake pedal stop light switch bracket. Original stamping original Bolt And original nut. Excellent condition. $50. PP FF
Old 09-18-2020, 04:00 PM
Early style (w/depression on the bottom) assembly line installed Temperature sender. AC DELCO upside down. $60 PPFF
Old 09-18-2020, 05:39 PM
3 NOS WEATHERHEAD 5/16" brass fuel line Fittings. 30 plus years old. New Fittings dont have the WEATHERHEAD stamping. $30 ea PPFF
Old 09-18-2020, 06:22 PM
Very nice original ACDelco brass temperature sender. With stamping upside down. Assembly line installed piece. $45. Ppff
Old 09-18-2020, 08:38 PM
Front brake line to frame distribution block with Weatherhead stamping on brass and steel bracket. Very nice very original 1/4" Inlet from master cylinder and Outlet to rear.
3/16" Outlets to front brakes. Perfect Survivor condition. $45. Ppff
Old 09-18-2020, 09:09 PM
69 Camaro dual exhaust rear tail pipe hanger to frame rail mounting bolts. Complete set of four original anchor head marking bolts. Very hard to find that are trusted. $40. Ppff
Old 09-18-2020, 09:15 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
I'll take these... will PM
70 Chevelle SS-454 LS-5 M-22
Enoch (09-18-2020)
  #119
Old 09-19-2020, 08:45 PM
Small block valve cover retaining bolts and S stamped hold Downs. Correct for steel valve cover equipped cars such as l79 and 67 and 68 Z28. $80. Ppff ************SOLD************
Old 09-19-2020, 09:48 PM
Excellent restored set of 68 through 72 big block Corvette valve cover bolts and retainers. The 4 A head marking bolts attach the spark plug ground straps to the valve covers and the 10 TR bolts secure the rest of the valve covers. $130. ************SOLD************
