#11
67 - 69 Camaro and Firebird emergency brake mounting hardware.
Set 1 has an E head marking bolt and nuts. 2 sets available. Set 2 has RBW headmarking bolt and nuts. $35 per set. *****ALL SOLD***** Last edited by Enoch; 01-01-2021 at 10:00 PM. |
#12
Excellent original restored antenna cable to rocker pinch Weld retaining clip. Very very nice and not being reproduced. $25. PPFF **********SOLD**********
#13
Perfect restored single Pole MB stamped courtesy light switch for a door jamb. Replayed it many years ago and sat on the shelf. $20 PPFF *******SOLD*******
#14
Original power window wire harness retaining clip. This was used on C 2 corvettes and on other models to retain the harness underneath the dash. $30. PPFF (X)
#15
Speculating that IF power window or rear defog runs down the pass side it would be used for their retention as well.
~JAG~ NCRS#65120 68 GTO HO 4 spd Alpine Blue /Parchment 2 owner car #21783 71 Corvette LT1 45k miles Orig paint - Brandshatch Green - National Top Flight - last known 71 LT1 built. 71 Corvette LT1 42k miles Original paint - Black - black leather - only black LT1 known to exist. NUMEROUS Lemans blue Camaros, Monza Red and Daytona Yellow Corvettes & a Chevelle or two... Survivors, restored cars, & other photos https://picasaweb.google.com/lh/myphotos |
The Following User Says Thank You to firstgenaddict For This Useful Post: | ||
Enoch (03-03-2020) |
#16
I believe you are correct! As that's what I've seen. |
#17
Excellent restored XS stamped single terminal courtesy light switch.$20. PPFF
#18
Excellent original unrestored assembly line installed Delco Remy dimmer switch, grommet and mounting bolts. You won't find a nicer original one. Works perfectly. $50. PPFF
************SOLD************ Last edited by Enoch; 10-07-2020 at 05:31 PM. |
#19
67 thru 70 bucket seat back release knobs and Allen set screws. Very nice original pieces.$25. PPFF (X2)
#20
Original tung sol 552 dash 12 Volt flasher dated 2 2 9 (February of 69) $20. PPFF (X2) ************SOLD*************
