Camaro disc brakes
I'm trying to take some of the drag out of my '69 Camaro. The front disc brakes drag a lot. If I try to spin the front tires they only turn about 1/4-1/2 round and stop. Is this normal for the factory disc brakes? I rebuilt the calipers several years ago. I'm probably going to use Wilwood or other after market brakes on it due to the drag of the originals. Any recommendations for good after market brakes that will work on the street with low drag?
IMO, that drag is normal.
Mike |
The Following User Says Thank You to m22mike For This Useful Post: | ||
big gear head (11-17-2019) |
----I believe that there are later model GM calipers that are low drag when they started to look for ways to bump MPG up. Drag racers know what I'm talking about.I was always going to do it to Red Alert, but never did. Not sure which years but know it works for what you are talking about. Oh,,,and they appear the same!.....Bill S
The Following User Says Thank You to olredalert For This Useful Post: | ||
front brakes
Freddie, Check with strange enginnering. I have the drag racing disc brake setup on my nova. But that setup is only for drag racing only. It;s marked on the instructions. But give them a call, and ask them about your application? BBBenny
Thanks Benny Enjoy; orginal cars,with orginal drivetrains and docs. bblocks are my favorite. |
The Following User Says Thank You to bbbenny For This Useful Post: | ||
big gear head (11-18-2019) |
That is why most drag cars remove the original style disc brakes because of the drag. Benny's set up is the way to go for drag racing.
The Following User Says Thank You to Salvatore For This Useful Post: | ||
I've been looking at some Airheart and Wilwood brakes. i'll look into the Strange brakes too.
