Day 2 Holley Wood Fiber Angled Base plate Gaskets?
$35 for the pair with FREE Shipping.
I have never seen these before. Chime in if you know exactly what application or usage these are for. Each gasket has an angled base made out of a wooden fiber and are in Excellent condition. IMO looks like it fits Holley carbs. *UPDATE* >> PHENOLIC RESIN is the gasket material which has a thermal conductivity rating of 2.01. While not as good an insulator as wood, it is far more resistant to fuel and chemicals, making a resin spacer more durable.
"NOSTALGIA It takes us to a place were we ache to go again" Last edited by XXXGoldL34M20; 01-15-2019 at 03:22 PM. |
----Possibly a marine application as us boaty people try to get the fuel bowls level...….Bill S
They are not wood, they are PHENOLIC spacers.
The following is from - https://www.onallcylinders.com/2014/...uretor-spacer/ Spacer Materials Let’s start with a spacer’s insulation properties. These are largely determined by the material a spacer is made from. There are four typical types of spacer material: wood, phenolic resin, polymer (plastic), and aluminum. Each has a different thermal conductivity (heat transfer) rating that tells you how well the material insulates against heat. The lower the rating number, the better the material insulates. Let’s look at each type: Aluminum is the worst insulating material of the bunch, with a thermal conductivity rating of 1,665.1. An aluminum spacer does offer three advantages—it’s very durable, is easily altered to help tune the intake charge, and is the only spacer material allowed by many racing sanctioning bodies. Wood is the best insulating material, with a thermal conductivity rating of 1.02. It’s also cheap and easy to shape. However, a wood carburetor spacer is the least resistant to gasoline and chemicals. It soaks up liquid easily, causing the spacer to warp, become porous (causing vacuum leaks), and break down faster. If you use wood spacers, inspect them regularly and replace if necessary. Phenolic Resin has a thermal conductivity rating of 2.01. While not as good an insulator as wood, it is far more resistant to fuel and chemicals, making a resin spacer more durable. Polymer is less expensive than phenolic resin. But with a thermal conductivity rating of 3.90, it does not insulate as well. Some polymers have been developed that insulate nearly as well as phenolic resin, so it pays to do your homework before you buy.
~JAG~ NCRS#65120 68 GTO HO 4 spd Alpine Blue /Parchment 2 owner car #21783 71 Corvette LT1 45k miles Orig paint - Brandshatch Green - National Top Flight - last known 71 LT1 built. 71 Corvette LT1 42k miles Original paint - Black - black leather - only black LT1 known to exist. NUMEROUS Lemans blue Camaros, Monza Red and Daytona Yellow Corvettes & a Chevelle or two... Survivors, restored cars, & other photos https://picasaweb.google.com/lh/myphotos |
The Following User Says Thank You to firstgenaddict For This Useful Post: | ||
jerry455 (01-15-2019) |
Thats Interesting !!
Hope My price is OK, as I have no idea what these are worth. Hopefully someone can use them. Thank you for the Info.
"NOSTALGIA It takes us to a place were we ache to go again" |
