Old 02-16-2020, 09:19 PM
Enoch Enoch is offline
5 TR Stamped rear wheel studs $20 PPFF
***********SOLD*************
Old 02-16-2020, 09:23 PM
Restored set of 12, L 5 head marking intake manifold mounting bolts for small blocks.$65 (X2)
Old 02-16-2020, 09:37 PM
Original assembly line installed GM 2 inch heat riser. very nice unrestored condition.$45. PPFF (X2) ************SOLD************
Old 02-16-2020, 09:52 PM
4 excellent original small block oil gallery plugs square socket.$20. (X2) ************SOLD*************
Old 02-18-2020, 08:51 PM
Original assembly line magnetic choke rod for the following applications.
66-69 427 425
66-69 396 375
Been sitting in my choke rod drawer for many years.
$50 PPFF
Old 02-19-2020, 07:34 PM
69 Z28 Power Brake Booser hose to valve cover stand. PERFECT RESTORED Assembly line piece. AAC STAMPED You wont find a nice original. $350 PPFF
Old 02-24-2020, 08:12 PM
NOS <CP> Oil line fitting. For both small and big block. $35.
5 available
2 or more $30 ea. PPFF (X2)
Old 02-24-2020, 08:30 PM
Original assembly line installed oil pressure line fitting for both small and big block. Weatherhead stamp. $35. PPFF (X2)
Old 02-24-2020, 10:53 PM
RBW head marking spark plug heat shield to block mounting bolts. Extremely nice restored set. $25. PPFF
(X2)
Old 02-24-2020, 11:03 PM
Excellent restored original set of 4 spark plug wire stand mounting bolts. These were sometimes used on the heat Shields for spark plugs but were also used on a wire stands that attach to the block. They have a captured lock washer and not an externally tooth star washer. $25. PPFF (X2)
