#141
Restored 68 through 75 Corvette positive battery cable to bellhousing mounting clip with perfect original Vulcanizing and M R stamping. Won't find a nicer one. $25. Ppff
#142
Original engine oil pan and transmission oil pan drain plugs. Included are both Styles large flat hex for Mid 68 and earlier and small hex for Mid 68 on up.
F-C $35 TR $35 D $20 RSC $20 PPFF |
#143
Excellent complete original restored set of Allen head door Strikers. Included are the two Allen head bolts with dimples on the rear and large attached washers.
Also included are 2 W-2 stamped 1/8" shims and 2 W-1 stamped 1/16" shims. $45 PPFF ************SOLD************ Last edited by Enoch; 10-09-2020 at 09:20 PM. |
#144
63 through 66 Corvette battery hold down stud and Wingnut. This is an assembly line installed piece with the tapered end and rolled threads. Not the reproduction garbage that doesn't even look close. $50. Ppff
************SOLD************ Last edited by Enoch; 10-09-2020 at 09:19 PM. |
#145
Excellent restored complete set of 69 Camaro Brake and fuel line mounting bolts. Included are 7 C head marking fuel line bolts with one small cad plated C head marking Bolt & B&N clip and 12 C head marking brake line bolts. $80. Ppff
#146
Excellent original pair of assembly line installed rear emergency brake cable connectors with stepped design. Great condition. $25 for the pair. ppff
#147
63 through 68 Corvette front and rear sway bar bushing mounting cups with C stamping. Have been stripped and zinc plated and are ready for black paint. $25. Ppff
#148
Camaro Firebird rear trunk catch and mounting bolts. Excellent restored pieces. The catch itself was stripped and zinc plated and the WB head marking mounting bolts are the correct short length with a wide thick washer with anti-skid nibs. Perfect setup for restored car. $25. Ppff
#149
EXCELLENT Original assembly line installed heater hose to Fender skirt mounting clip. The reproduction in the pictures is the silver one the original is the black one. You can see several noticeable differences between originals and reproductions. $25. Ppff ************SOLD************
#150
4 very nice original stripped and replated wheel well to Inner fender support cops. $30 for the set of four. The stampings are different than the Repros. Pete PFF
