Old 02-05-2020, 08:15 PM
Enoch Enoch is offline
Default #3 Camaro Chevelle Nova Chassis/ Suspension/ Under Carriage
***********************************this thread is closed-all items have either been sold or moved to other threads*******************************************
Any questions? Don't hesitate to contact us.
We appreciate you stopping by and browsing our items!
Attachments - The Supercar Registry 20200918_182319_copy_1032x774.jpg 20200918_182301_copy_1032x774.jpg 20200407_194225.jpg 20200407_194212.jpg
Old 02-05-2020, 08:17 PM
Original restored brake and fuel line clips. #6. $15 each *****3 REMAINING*****
Original restored brake and fuel line clips. #4. $15 each (X1)
Old 02-11-2020, 11:39 PM
67-69 Camaro Firebird 70-72 Nova 11/16 Original front sway bar to frame bushings. This is an original pair that was removed from a Very low mileage 67 pace car back in the early nineties. As nice as you're going to find. The re pros don't look anything like these. $50. PPFF *******SOLD*******
Old 02-16-2020, 06:40 PM
Original upper a arm rubber bumper. This is an assembly line piece not a reproduction. $20. PPFF ********SOLD********
Old 02-16-2020, 06:45 PM
Original lower a arm bumper. with part number. this is an assembly line piece.$25. PPFF **********SOLD**********
Old 02-16-2020, 07:03 PM
Original reverse lockout / back drive swivel and stamped spacer.$20. PPFF *******SOLD*******
Old 02-20-2020, 05:29 PM
Excellent original restored emergency brake cable to sub frame connector rod. With flat end and X stamping. As nice as your find. $50. PPFF *******SOLD*******
Old 02-24-2020, 10:20 PM
This is probably need nicest unrestored set and truly untouched set of SEMS head marking rear upper shock mounting bolts. Some dirt on their heads but still retains all of its black plating. Perfect patina. You won't find a nicer original set. $45. PPFF *******SOLD*******
Old 02-24-2020, 10:46 PM
Excellent original unrestored complete set of 6 1st generation Firebird/Camaro convertible under body X brace mounting bolts. I had marking. No rust just dirt on them. Won't find a nicer unrestored set. $45 PPFF
