Old 12-30-2018, 03:43 PM
Unreal Unreal is offline
Cars built with the VE3 bumper had an adapter riveted to the jack loadrest, usually painted blue.
I've asked this before, but never got an answer. Was the entire load rest painted blue, or was the adapter blue, while the hook remained gray. If that's the case, would the rivet be left unpainted?
Old 12-30-2018, 03:58 PM
William William is offline
Looks like an original.
Old 12-30-2018, 09:09 PM
Thanks William. That was what I wanted to know. Now to find someone who can install a large rivet. Spring shop, maybe?
Old 12-31-2018, 02:41 PM
rlw68's Avatar
rlw68 rlw68 is offline
Is this a semi tubular or solid rivet ?
Rob
Old 12-31-2018, 03:34 PM
Copo_Cartel's Avatar
Default Ve3
NOS VE3 Hook
The Following User Says Thank You to Copo_Cartel For This Useful Post:
rlw68 (01-01-2019)
  #26
Old 12-31-2018, 04:29 PM
m22mike's Avatar
m22mike m22mike is offline
If your asking about the rivet by the VE3 stamp, that's a tubular, or semi tubular rivet.
Old 01-01-2019, 04:41 PM
rlw68's Avatar
Yes, that rivet , thanks. There are repops for both the VE3 part of the bracket and the entire thing. I have a load rest already that the bracket can be attached to with the rivet. Its stamped 'Camaro 1969" without the "UN" though. I assume this is still correct?
Rob
Old 01-01-2019, 05:39 PM
You can tell a difference between the real VE3 hook and the repop
Old 01-07-2019, 01:33 AM
The real ones are stamped and the difference in the edges of a laser cut VS a die stamped part is quite noticeable.
Tags
ss z28 rs copo yenko
