Old 05-08-2019, 02:36 PM
Those look great. I really need to swap out my 15x10's for 15x8's on the rear and 15x7's for 14x6 for the front. The look is so much nicer.
1968 Camaro Ex-ISCA Show Car
John 10:30
69 Post Sedan (05-21-2019)
  #402
Old 05-21-2019, 10:10 PM
69 Post Sedan's Avatar
Another update on my pressure plate issue.....the McLeod pressure plate they they adjusted for me worked fine for normal driving but when at a dead stop and launching the car, on the street mind you, it slipped.....AGAIN. Apparently the 2800 pound clamping force, that they guaranteed to work, isn’t enough!!! So, I’m getting a refund on the pressure plate as soon as I take it out and send it back to them.
Now, after a lot of research and talking with a new company, Advanced Clutch Technology (ACT), out of Lancaster, CA, has a diaphragm pressure plate and organic disc that has 3900 pounds of clamping force. Stock is about 3000 pounds. I should be getting it later next week because they have to make the disc and it takes 3-4 days to get to Wisconsin from California.
This kit should work........keep your fingers crossed!!!
https://www.summitracing.com/parts/acl-gm6-hdss
Kurt
1968 Schwinn Orange Krate Original Paint
1970 Schwinn 3-Speed Deluxe Original Paint
The Following User Says Thank You to 69 Post Sedan For This Useful Post:
Copo_Cartel (05-29-2019)
  #403
Old 05-21-2019, 10:48 PM
Glad you are getting a refund.
Well done
  #404
Old 05-29-2019, 12:37 AM
The ACT clutch kit is on its way.....I should get it by the end of this week or early next week.
On a side note......I’m still fighting a gremlin with what I believe to be an ignition problem. I thought I had it solved when I eliminated the CDI box but it’s acting up again. It started fine this spring but anytime I get the rpms up over 4000 or the secondaries kick it, it spits, sputters and sometimes backfires. The other day, I barely got it home......had to keep the rpms up over 1500 to keep it running.
I talked with a friend today (electrical genius) and he said since my Mallory Unilite distributor is old, that the ignition module might be bad....especially since I’ve replaced and/or eliminated everything else. He said he had the same thing happen to him and that was his issue.
So I took the distributor cap off and found an e-clip sitting in the distributor, I have no idea where that came from or where it goes/went. I then took the distributor out to make sure I ordered the correct ignition module and noticed the shaft was moving up and down quite a bit. As I spun it, I noticed the head of a screw was marred up from hitting/rubbing on something.....like the bottom of the plate where the module bolts to. So I bit the bullitt and ordered a new distributor, new Comp Cams composite gear among other things for the clutch replacement.
When I get the distributor installed, EVERYTHING for my ignition will be new!!! $$$$$$$
Let’s hope this resolve this issue.......I need to have it running good for the NOCC show or Dan will be upset.......and we don’t want to do that!!!
Kurt
The Following 2 Users Say Thank You to 69 Post Sedan For This Useful Post:
Copo_Cartel (05-29-2019), scuncio (06-02-2019)
  #405
Old 05-29-2019, 01:35 AM
You have 2 months.....you have plenty of time.
Sounds like you have already found the problem
Old 05-30-2019, 11:15 AM
kwhizz kwhizz is offline
With a LSA you wouldn't have those issues...…….. LOL
Old 05-30-2019, 11:59 AM
Next year........
Old 05-30-2019, 05:28 PM
Originally Posted by 69 Post Sedan View Post
Next year........
Next Year? Who’s leg are you pulling?
Not happening
Old 05-31-2019, 02:40 PM
Not happening
Putting an LS in the car is taking the easy way out.....lol
The car has ran great for 9 years.....this is just a little hiccup that will be resolved in a couple weeks or less....hopefully..... #crossingfingers
Kurt
Old 06-01-2019, 11:42 PM
So, I had to wait for the correct distributor gear as I ordered exactly what I had on the old distributor, which is the same part number. Well the old distributor has a .491 diameter shaft and the new one is .500. 😡
I actually read the instructions on the wiring and it said to install a 1.6 ohm resistor.....although my old one didn't need one. So I ordered that too and installed it along with the correct distributor gear. It started right up and seems to run good. I need to set the timing tomorrow. “Maybe” take it for a spin too!!!
Kurt
