1969 Camaro Park/Turn Lights
This ad is for: 1 pair of refurbished – used- (original) repaired (*Relugged, Rewired, Resleeved, Reinsulated, etc) original park light assemblies for a 1969 Camaro. These assemblies have been disassembled, cleaned, glass beaded, polished, welded, plated, painted, reassembled and Bench tested. These ARE originals not reproductions. Including the Made in USA stamping on back side and the GUIDE 12 SAE IP69 stamping on the inside of the housing. The assemblies have been carefully disassembled and cleaned and Zinc –Dichromate plated to 'replicate' the as manufactured appearance, you cannot get by purchasing reproductions or by painting. The wiring harness has been cleaned or repaired and preserved, The socket-wire & contacts has been replaced and tested for proper operation. The Packard series 56 wire female spade terminals have been cleaned or replaced (Properly Crimped). Included are NEW mounting (Like 271172) AMK nuts. 1/4-20unc w/ attached external tooth locking washer. Parking Lamp 916911, Wire Blk Turn +12vdc, Wire Ppl Park +12vdc, Housing -12vdc. (Bulbs NOT supplied) Proof of operation documented - photo attached to each lamp assy.
These ARE used parts that have been cosmetically restored . Why settle for repops, when the hard work has been done for you. Easy to swap out your tarnished worn assemblies & renew a very visible item on your vehicle. Shipping size is (appx) 11” x 9” x 6” @ 1.5lbs Pricing (*Discounted re. metal finish) $175 USD plus shipping from ZIP 98314 (WA) Paypal "Friends & Family" PM me if any ?'s Attached Images (Set-B) % Photo added of lamp in installed position to give view of housing from above.
69 Los Z11 68 SS/RS 396/325 68 Los Z28 |
