Old 07-24-2019, 08:14 PM
ALLZS ALLZS is offline
Is it $20.00 shipped on the p/s hose clip
The Following User Says Thank You to ALLZS For This Useful Post:
Enoch (07-24-2019)
  #102
Old 07-24-2019, 08:15 PM
Enoch Enoch is offline
Yes it is. Thanks oh, I have several of them
Old 07-24-2019, 08:19 PM
Original 10 bolt rear end rubber brake line 2 rear end cover mounting bracket and original rbw head marking shoulder bolt for brass block. $35 ppff. Bolt is in excellent condition and the bracket is in excellent condition both have been replated.
Old 07-24-2019, 09:03 PM
1970-up TCS temperature wire 2 valve cover wire separator mounting clip. Excellent original piece. Unrestored. Still has perfect rubber Vulcanizing on it. $45. Ppff
************SOLD************
Old 07-24-2019, 09:14 PM
I will take 1 of the p/s clips
Enoch (07-24-2019)
  #106
Old 07-24-2019, 09:21 PM
Thanks, PM sent
Old 07-25-2019, 03:07 AM
Mulsanne Blue Mulsanne Blue is offline
Default 1970-up TCS 2 wire clip.
Rich, I'll take the clip.
The Following User Says Thank You to Mulsanne Blue For This Useful Post:
Enoch (07-25-2019)
  #108
Old 07-25-2019, 01:39 PM
Thanks Scott I'll mark it sold and send a PM
Old 07-25-2019, 06:53 PM
Originally Posted by Enoch View Post
Three sets of original unrestored 1967 through 1969 Camaro rear spoiler mounting hardware. All large washer nuts have anchor stamped underneath them 2 sets have acorn nuts for the rear bolts and one set has small washer hex nut for the rear bolts. $80 per sets PP FF
Rich, are there different time frames when the acorn nuts were used instead of just the captive (washer) nuts? Early car, late car etc.?
Thanks, Sam
The Following User Says Thank You to Salvatore For This Useful Post:
Enoch (07-25-2019)
  #110
Old 07-25-2019, 08:02 PM
Sam, that one I can't honestly answer. I do know of several original cars that I did restore our work on that had acorn nuts. And the ones that I had seen ranged from April 69 to September 69. I'm sure there's other dates thrown in there and maybe earlier years even, I don't know but that's what I've personally seen.
