Old 10-18-2023, 04:43 PM
Chuck_Burg's Avatar
I can tell you the Torker works just fine. Power wherever you want it... It just falls off too soon. If I don't like the Tarantula, I can always put the Torker back on
The Following 3 Users Say Thank You to Chuck_Burg For This Useful Post:
jbtech (10-18-2023), napa68 (10-18-2023), Xplantdad (10-18-2023)
  #472
Old 10-18-2023, 10:04 PM
GrumpyJeff's Avatar
GrumpyJeff GrumpyJeff is offline
Originally Posted by Chuck_Burg View Post
Thanks guys!
It ready has a single plane on it Mitch, a Torker. Plus it’s a 496” engine, don’t think it’ll lose much torque lol
Tire pressure isn’t the issue, watch the rear bounce up. Needs a better shock, which is in the works. Got a very experienced drag racer helping me with this.
I run those same tires on my 67 @18lbs, minor burn out like yours , generic NAPA shocks on rear, 90/10 drag shocks on front , I leave at 3500 shift at 6000 1.57 60 ft
The Following 2 Users Say Thank You to GrumpyJeff For This Useful Post:
Chuck_Burg (10-19-2023), napa68 (10-19-2023)
  #473
Old 10-19-2023, 08:45 PM
Chuck_Burg's Avatar
That is hookin' and bookin'! What gear do you have?
ACR (10-20-2023)
  #474
Old 10-19-2023, 08:53 PM
napa68 napa68 is online now
In the name of 60' times, you probably could afford to give up some torque
Chuck_Burg (03-28-2024)
  #475
Old 10-19-2023, 09:01 PM
Chuck_Burg's Avatar
I agree Tim! I don't have the intention to race much but you know how addicting it is...
napa68 (10-19-2023)
  #476
Old 10-20-2023, 02:30 AM
SPEEDYB SPEEDYB is offline
Sounded good at Irwindale, I was there!
Im sure that 496 will respond good with that
Tarantulas bigger port volume.
The Following User Says Thank You to SPEEDYB For This Useful Post:
Chuck_Burg (10-20-2023)
  #477
Old 10-20-2023, 03:40 AM
Chuck_Burg's Avatar
Thanks Speedy! It’s got plenty left in it. My buddy who built the engine and I have been looking for a TM2-O for a while with no success. Want this when we built the engine back in 2019! You going to In-N-Out 75 at Pomona this Sunday?
Old 10-20-2023, 01:51 PM
We were going to race at Pomona but the event is sold out!
Ill keep my eyes peeled for an oval port Tarantula thou!
Old 10-20-2023, 06:52 PM
Chuck_Burg's Avatar
I'm running at Pomona
I found the Tarantula! Taking it to get Vaporhoned today
The Following 2 Users Say Thank You to Chuck_Burg For This Useful Post:
dykstra (10-20-2023), napa68 (10-20-2023)
  #480
Old 11-01-2023, 05:34 PM
Chuck_Burg's Avatar
We had a blast at Pomona. Good times with friends and family. I got to make two passes, should've been three but I blew a heater hose in the burnout box and had to get pushed off the track haha. Talk about embarrassing in front of almost full grand stands Best was a 12.17 @114mph. The car was starving for fuel (sputtering on the big end at the top of 3rd gear and 4th gear) so I made a jet change and it actually hurt it more. Fuel pump can't keep up with demand....
I was really thinking it would run high 11s considering the weight of the car, over 3600lbs without driver, and the 3.55 gears so I'm close. I am going to convert the car to 1/2 hard fuel line with a 1/2" pickup and an Edelbrock mechanical pump.
After the track I conducted a fuel pump volume test after talking to some drag racing buddies. I removed the fuel line on the secondary float bowl and plugged it into a rubber hose draining into plastic jug. My mechanical pump only pumped 8-9oz of fuel in 12 seconds. Turning on my electric pump, which I had on during the runs at the track, I saw 29oz of fuel in 12 seconds which is about .2 gallons. Probably very close to the amount of fuel I need in a 1/4 mile... too close for comfort!
Not that the car is a drag car but I want to be prepared next time. Some things can only be discovered on the track!
After I install my new fuel lines and pump, I will install the Tarantua TM2-O intake and bring it to the dyno to make sure we have enough fuel!
The Following 9 Users Say Thank You to Chuck_Burg For This Useful Post:
1-slow-camaro (11-02-2023), dykstra (11-02-2023), L_e_e (11-01-2023), markinnaples (11-02-2023), napa68 (11-01-2023), olredalert (04-17-2024), SMS (11-10-2023), x77-69z28 (11-03-2023), Xplantdad (11-01-2023)
