Old 07-17-2023, 01:58 AM
Vortecpro Vortecpro is offline
Default 375 HP 396 MQ Code 1968
375 HP 396 MQ code 1968 short block:
Block .030
Crank Std Std cross drilled 6223, no problems
3/8 dimple rods, no problems
TRW L78 replacement piston
L78 Harmonic balancer
L78 Timing chain cover
L78 oil pan
L78 rocker arms
L78 pushrods
L78 Valve covers
Deep grove lower pulley
Engine is in very good shape with ZERO rust issues, and pristine code (MQ). Can be cleaned honed and reassembled. Short block 2600.00 OBO. I also have the 840 heads with out a million valve jobs, but need them for another project but could possibly be talked out of them. All parts listed are original to this engine.
Old 07-17-2023, 02:36 AM
luzl78 luzl78 is offline
What is the casting date and build date and vin?
The Following 2 Users Say Thank You to luzl78 For This Useful Post:
Maxsg1973 (07-29-2023), PeteLeathersac (07-17-2023)
Old 07-17-2023, 03:38 AM
323 block casting, I need to get it out from the bench it sits under and I will post the date code, I do need to have the vin run.
Old 07-28-2023, 09:32 PM
Sold
Old 07-29-2023, 06:03 PM
Pacecar1969 Pacecar1969 is offline
Default 1968 Short block
What is the engine assembly date and casting date ?
The Following User Says Thank You to Pacecar1969 For This Useful Post:
