Old 04-02-2013, 09:30 PM
ss427copo's Avatar
ss427copo ss427copo is offline
Default Bake Fluid Advise...
I got around to replacing the brake lines after locating an NOS master cylinder for the Camaro. Now, any advise to use silicone or standard brake fluid when I'm ready to bench bleed it and install the lines?
Jersey Jeff
69 Day-2 L89 T400 BX
2015 ZL-1 Auto
98 Surburban
Old 04-02-2013, 09:54 PM
Mk IV Muscle Mk IV Muscle is offline
Default Re: Bake Fluid Advise...
Stay far away from silicone fluid! More trouble than it's worth IMO. Use a good synthetic DOT 4.
Remember the days of carburetors,chrome,and leaded gasoline?
1969 Nova SS L78 4-speed
Old 04-02-2013, 10:25 PM
SS427's Avatar
SS427 SS427 is offline
I used to use silicone exclusively on my restorations due to the effects of Dot 3 on painted surfaces. However the companies that reline master cylinders and wheel cylinders will no longer warrant their work if you are using silicone so that alone has forced me to switch back. The other issue is because of the viscosity of silicone it is VERY prone to leaking no matter how tight you think you may have some joints. Since going back to Dot 3 I have not had an issue. I just have to be a LOT more careful during the bleeding process. I have never used DOT 4 so I cannot add to Mk IV's comments.
Rick Nelson
Old 04-03-2013, 12:47 AM
I would paint your master cylinder black except where ports are machined etc.
Old 04-05-2013, 04:58 AM
ss427copo's Avatar
Yea Charley, I'm getting around to painting it black. Semi gloss according to Jerry M?
Jersey Jeff
2015 ZL-1 Auto
98 Surburban
Old 04-05-2013, 10:57 AM
njsteve njsteve is offline
I use Rustoleum flat black - its ends up looking closer to the original finish than the too-glossy semigloss.
Old 04-07-2013, 05:10 AM
Kurt S Kurt S is offline
To be like the factory paint, it should fall off after a week or two..... [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Kurt S - CRG
Old 04-07-2013, 12:57 PM
Tommy's Avatar
Tommy Tommy is offline
Here you go Jeff. CLICK HERE
Tommy [img]<<GRAEMLIN_URL>>/[/img]
