Old 08-29-2022, 12:03 AM
Copo_Cartel's Avatar
Default Dash Pad
Hello all. I am looking for a good source to restore an original assembly line 69 Camaro dash pad non-AC . It is not cracked but has shrunk . Thanks in advance .
Old 08-29-2022, 03:39 AM
Justdashes.com Watch the Jay Leno video of the 17K mile Jaguar XKE on here. They are in there. Tells the story and process.
Bill
Old 08-29-2022, 11:18 AM
bergy's Avatar
bergy bergy is online now
Has anyone had experience with Just Dashes restoring 69 dash pad? Wondering how they do on getting the shrunk up ones to properly cover the VIN rivets. Anybody have pics?
Copo_Cartel (08-29-2022)
Old 08-29-2022, 11:39 AM
William William is online now
In my 46 years in the hobby/business I have never seen a '69 dash pad repair last more than a few months.
Main problem, the liner is plastic. By the time it shrinks and warps, the foam is hard as a rock. You can trim the liner back and re-glue the foam, won't last. Keeps warping, the studs pull out; corners break off. And as noted, the VIN rivets will be visible.
Don't bother with NOS should you find one. The tooling was different, no bead along the leading edge. Most had a bald spot in the middle.
Latest repro is excellent. That's the smart move.
The Following 2 Users Say Thank You to William For This Useful Post:
bergy (08-29-2022), big gear head (08-29-2022)
Old 08-29-2022, 01:36 PM
Thanks everyone. Great advice and ideas.
Old 08-30-2022, 01:36 AM
William, which repro do you like? Does the same hold true for a 69 Chevelle dash pad? I need both!
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle
Old 08-30-2022, 11:54 AM
The latest repro, known as the "OE style" is the best of the two repros, I hear. About $370.
In stock at D & R Classic Auto.
Old 08-30-2022, 01:29 PM
Starship Starship is offline
I used Just Dashes to rebuild the pad in an '85 Suburban. Expensive , but, results are perfect. 2 years so far without issues.
Old 08-30-2022, 02:27 PM
D+R are easy to deal with. Steve is a good guy!
Old 08-31-2022, 03:22 AM
nova67 nova67 is offline
Default dash
I used Just Dashes to restore a 70 GTO dash and console turned out perfect not cheap tho!
