Old 04-08-2020, 12:12 AM
68bronze 68bronze is offline
Banned
Send a message via AIM to 68bronze
Default dist
Originally Posted by rszmjt View Post
The Facebook distributor is real
looks like to me that the last 8 is a restamp over the eight!! my two cents worth
Old 04-08-2020, 12:16 AM
Jonesy's Avatar
Jonesy Jonesy is offline
Its pretty obvious the 6 and 7 in the first post are not like the other numbers
The Following User Says Thank You to Jonesy For This Useful Post:
68bronze (04-08-2020)
  #13
Old 04-08-2020, 12:24 AM
rszmjt rszmjt is offline
The distributor numbers are not stamped into the housing, the distributor housing is rolled against a fixture that held the characters, sometimes double imprints or ghosting does occur.
Compare the last 3 numbers of the Facebook “distributor number “ to the one initially posted and you will notice why the 1st one is phony. I don’t like to post the actual font issues as it’s something that I’ve got notification from people before not to do to clue in the stampers.
Old 04-08-2020, 12:43 AM
Another good way to tell a restamped distributor is by the upper housing diameter, it should measure 3.810 where the numbers are and the upper undercut area for cap should measure 3.795 for approx .200 before it gets to the 3.810 diameter. If you put a distributor cap on a restamped hsg it will move on housing if you push it. They have to turn the housing down to eliminate the original numbers before restamping so diameter is smaller than original. Another good trick is to spray the number area with brake cleaner, if it’s been welded up and restamped you will see shiny areas because of the different metallurgy of housing and filler rod used.
The Following 4 Users Say Thank You to rszmjt For This Useful Post:
69z2x4 (04-08-2020), NorCam (04-08-2020), parkbrau (04-09-2020), Xplantdad (04-08-2020)
