Old 10-29-2019, 02:07 PM
SS427's Avatar
SS427 SS427 is offline
Default Totally restored 1970-73 RS Camaro hood release
For sale, a mint, totally and correctly restored 1970-73 RS Camaro hood release. The release was media blasted, acid washed, rinsed and then correct dark grey phosphate from Steve Gregori was applied along with correctly restored release springs and then finally sealed in Boe-Shield. NO paint use anywhere, only correct plating. In perfect condition and ready to bolt on your Camaro. ***SOLD*** Please PM or email me if interested. Thanks sYc.
Rick
Rick Nelson
The Following User Says Thank You to SS427 For This Useful Post:
ScottG (10-29-2019)
Attachments - The Supercar Registry tn_10013714.JPG tn_10013713.JPG tn_10013712.JPG tn_10013711.JPG
Old 10-29-2019, 03:47 PM
This one looks technically correct for 71-73 as its missing the welded on second horn nut that was 70 only. It's easy to add the second nut without welding. Actually makes it a bit more "universal".
Either way, it's a great deal.
Owned since 1978 - First Car
Old 10-29-2019, 04:21 PM
SS427's Avatar
This is a spare from a 70 Z28 RS I am restoring and neither this one or the one on the car has the welded nut on the release. What I found was that the vertical support brace has the welded nut in it on the passenger side that would also support the horn. From what I can find in the assembly manual the support brace also shows the welded nut to bolt on the passenger side of the hood release and horn. Please correct me if I am wrong but I think this is correct.
Rick Nelson
chevyman0429 (10-29-2019)
Old 10-29-2019, 04:37 PM
SS427's Avatar
The GM parts manual shows the 70 vertical support bracket with welded nut using the part number 3962995 (which is what I have) and states that is the same part number for 70-73 for RS and standard Camaro. Regardless, as stated, this release will fit those years and is a very good deal at that price.
Rick Nelson
Old 10-29-2019, 07:16 PM
SS427's Avatar
Sold! Thanks sYc
Rick Nelson
