Old 12-19-2021, 06:00 PM
wayoutz wayoutz is offline
Yenko Premier Member
Default C2 corvette vinal hardtop storage
Ok need your opinions on this. Have a beautiful 67 corvette vinal hard top and thinking on storing on the storage cart shown. Do you think the padded form will leave marks on the vinal where the top is resting? Since the picture I added each side a padded oven mitt just for more padding.
1969 Z28 DAYTONA YELLOW SURVIVOR
1969 Z28 DUSK BLUE X33 BORN WITH DRIVE LINE SURVIVOR
1969 Z28 GLACIER BLUE ON BLUE X33 RS
1969 CORVETTE 427/435 (MA6) BLOOMINGTON GOLD SURVIVOR
1966 CORVETTE 327/350 L79 BLOOMINGTON GOLD
1978 CORVETTE L82 4SP SILVER ANNIVERSAY 9K MILES SURVIVOR
1967 CORVETTE L79 Convertible
1970 Z28 CLASSIC COPPER FRAME OFF RICK NELSON
Old 12-19-2021, 09:09 PM
----I have exactly the same hardtop storage rack. I have my top turned around with the paint (vinyl in your situation) pointing outward. I then got a length of wood the appropriate length (longer than the hardtop is wide, and taped it to the very top so that the rack wouldn't hit the headliner. Works slick as the wood just rests on the weatherstrip!.....Bill S
Old 12-20-2021, 12:31 AM
Thanks Bill. Would it be to much for you to attach a picture of yours with the wood attached?
Old 12-20-2021, 03:19 PM
----I will have to E-mail you a pic.....Bill S
Old 12-20-2021, 07:19 PM
DW31S's Avatar
DW31S DW31S is offline
May I offer a word of caution...if those tops aren't stored properly, they spread. I bought a roadster that came with a hardtop that was sitting in a loft of the pervious owner's garage. We tried to install the top when I was picking up the car and it wouldn't fit. Ultimately, we did get it on and latched, but over time the corners had spread at least an inch.
Old 12-24-2021, 05:56 PM
Default pictures
Thanks a bunch. I followed your pictures and it works great
The Following 2 Users Say Thank You to wayoutz For This Useful Post:
69M22Z (12-24-2021), olredalert (12-24-2021)
Old 12-24-2021, 07:18 PM
----I like the additions you made!.....Bill S
Old 12-24-2021, 09:26 PM
njsteve njsteve is offline
I would think that in order to stop the "spread" of the mounting points, you could get a long section of threaded rod and a couple of nuts and washers, and route the rod through the two lower mounting tabs, with the nuts/washers on the outside. (Or you could use another section of wooden broom handle just like you have in the above photos, cut to length with some screws and large washers screwed in each end.
This way it would act as a stop to prevent the spread.
