Old 04-10-2021, 09:10 PM
X66 714's Avatar
X66 714 X66 714 is offline
Default Water shields for 1968/69 Camaro wanted
I'm looking for the water shields for 1969 Camaro that go behind the door panels for deluxe interior. I need at least 2 sets please. Thank you, Joe 520-490-6093
Old 04-11-2021, 02:20 AM
They are not visible once panels are installed.
Any body shop supply house will have a roll of plastic water shield which is superior to the ones GM used. They have adhesive on one side, just like a roll of tape. Cut to fit. They work great.
If you don't want to buy a whole roll, maybe you know someone in the business that can help you out with a couple of short pieces.
X66 714 (04-11-2021)
Old 04-11-2021, 02:59 AM
X66 714's Avatar
Thanks Lynn. For this car they have to be the real thing....Joe
Qtown Ed (04-11-2021)
Old 04-11-2021, 03:11 AM
I get it.
Old 04-12-2021, 04:57 PM
You could buy some kraft paper and make the cups out of plastic how the originals were made.
The water resistant back was black latex - Latex in liquid form is available, ADD CARBON BLACK and apply using a paint roller.
X66 714 (04-12-2021)
Old 04-12-2021, 06:23 PM
AnthonyS's Avatar
^ make a pattern and start listing sets here - several would be interested I would bet!
Old 04-12-2021, 06:36 PM
X66 714's Avatar
Thanks for it information. I really didn't think I was going to have this problem. I found the rears from both my Camaros but the fronts got ate up by something where I stored them 40 years back. UGH! Thank you, Joe
Old 04-12-2021, 06:45 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Are the water shields different between the deluxe and standard interiors?
I would think they may be the same??
Old 04-12-2021, 07:06 PM
KevinW KevinW is offline
They are different! The deluxe water shield have a flexible plastic section that goes around door pull mech. The chrome door pull is then bolted on top, creating holes through the bag
Standard just has a hole for the door pull shaft.
69 327 convertible (driver)
The Following User Says Thank You to KevinW For This Useful Post:
The deluxe water shields have a plastic pocket where the interior door pull is located, the std interior shields do not.
If the photo doesn't show there is a link below.
https://photos.app.goo.gl/dJBwjPpE9cPWdMjWA
The Following 2 Users Say Thank You to firstgenaddict For This Useful Post:
bbbentley (04-13-2021), X66 714 (04-12-2021)
