1962 positraction lube/additive ?
I just had a posi built for my '62 and am wondering if there was a different additive for these with no fabric on the discs. It is all original parts, no aftermarket, except the new clutch packs.
My builder said to just use what is/has been available, but thought I would see what the people with these posi's are using. I will be using standard oil based gear lube. Thanks
Mitch 1970 Chevelle SS 1966 Chevelle SS 1967 Camaro ss/rs 1938 Business coupe, street rod 2000 FXSTS, original owner, 13k miles Last edited by Too Many Projects; 06-07-2021 at 12:40 PM. |
This is what I have been using with no issue.......
https://www.lubegard.com/products/lss/ Available everywhere Tim |
The Following User Says Thank You to napa68 For This Useful Post: | ||
Too Many Projects (06-07-2021) |
The GM limited slip oil additive is still available and works pretty well. I like the Ford additive better. It works well with problem differentials like the Auburn. Sometimes 2 bottles of additive are required.
The Following User Says Thank You to big gear head For This Useful Post: | ||
Bought some today at the dealer, it is up to $15
1969 ZL1 COPO Camaro 11.60@120 F.A.S.T 21 1971 LS6 vette 12.20 @118 PSMCDR |
The Following User Says Thank You to 1971ls6 For This Useful Post: | ||
Too Many Projects (06-08-2021) |
I'm liking what I read about the LubeGard being formulated for cone and steel clutches.
All of them are. GM has always had steel clutches and cones in their cars and trucks up to somewhere in the '90s. Chrysler too. Ford used clutches with fiber lining and still does.
I know Pontiac posi's were cones, but all the 12 bolt posi's I've worked on had a combination of fabric and steel plates.
The LubeGard is about half the cost of the GM additive... If it works just as well. Of course, they claim it's better.
All of my late 60s GM cars, was always told to use GM posi lube only. Just my two sents.
Gregg |
All of the factory installed Eaton Posi units in the 12 bolt and 8.2 10 bolt had steel clutches, 18 discs and 200 pound springs in the standard units and 22 discs with 800 pound springs in the heavy duty units. After market Eaton Posi units today have carbon fiber lined clutches, 14 discs with 400 pound springs. The Traction Lock differential in the 8.5 corporate 10 bolt had steel clutches. GM used the Auburn cone unit in some of the 8.5 rear ends and all of the 7.5 car rear ends that got the limited slip differential. Starting in '90 the 8.5 in the Impala and Caprice got the Auburn. The truck Eaton locking differential had steel clutches until sometime in the '90s I believe and then went to the carbon fiber clutches. All of the old Chevy '55-'64 rear ends with limited slip had steel clutch plates. The Buick, Olds, Pontiac 8.2 rear end had cone Borg Warner differentials. The '04-'06 GTO also had a Borg Warner cone differential. Torco oil is the only oil that will work in these GTO rear ends. GM has been dealing with steel on steel for a long time.
Freddie 1969 Camaro RS/SS396 (427) 4 speed Last edited by big gear head; 06-08-2021 at 12:04 PM. |
ruralrte66 (06-08-2021) |
Thread Tools | |
Display Modes | |
