Cheap '71 4-speed Corvette, $3500
I see a 6500-rpm redline tach on this one - maybe an original LT1 car? In any case it's pretty clean for the opening bid price of $3500 - guessing it will end around $7k.
Link to 1971 Corvette auction 194371S103191 |
The Following User Says Thank You to scuncio For This Useful Post: | ||
markinnaples (01-02-2020) |
----Don't know what all is wrong here but the car has to be worth 5 to 7 grand...…Bill S
LT-1, unless someone changed the engine date plate
I asked the seller to post a pic of the data plate.
If that plate is original to the car, it appears to be an LT-1.
The fan shroud and a few other details also make it appear to be a LT-1 car.
IT is a LT1 -
The blue sticker in the door jamb has the ENGINE SUFFIX imprint in reverse in the lower left corner... the sticker was stacked together with the PROTECTO PLATE and POP leaves an imprint in many cases. The car is unmolested even has the correct 5 port washer pump with 2 ports bridged. Only 71's SB with smog manifolds and a brass radiator are LT1's... thats the original radiator and bet if you look inside the drivers front fender in front of the tire on the inner fender there are 3 holes for the TI box.
~JAG~ NCRS#65120 68 GTO HO 4 spd Alpine Blue /Parchment 2 owner car #21783 71 Corvette LT1 45k miles Orig paint - Brandshatch Green - National Top Flight - last known 71 LT1 built. 71 Corvette LT1 42k miles Original paint - Black - black leather - only black LT1 known to exist. NUMEROUS Lemans blue Camaros, Monza Red and Daytona Yellow Corvettes & a Chevelle or two... Survivors, restored cars, & other photos https://picasaweb.google.com/lh/myphotos |
The Following User Says Thank You to firstgenaddict For This Useful Post: | ||
PeteLeathersac (01-10-2020) |
Sold for $11,318. Seems like a decent car for the money. The right color too.
