Old 09-24-2022, 12:38 AM
WILMASBOYL78's Avatar
Post Head Lamp Upgrade...
Looking to improve the head lamps on my 85 GMC pickup...square body truck with rectangular head lamps. Current lights don't do much by today's standards.
Looking for bolt in upgrades that are an improvement but don't break the bank.
Suggestions??
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 09-24-2022, 02:39 AM
LT1vette LT1vette is offline
HID's..... not LED's. Should brighten up your night..
Old 09-24-2022, 04:46 AM
Old 09-24-2022, 02:12 PM
I don't think they make a quality lamp for LED's. The reflector on the 5" headlight "sprays" the light too much, blinding on coming drivers.
Do some research on the differences and make your decision. I changed mine to HID's and they are very controlled in their projection and cut off of the beam...
HTH..
Old 09-24-2022, 04:13 PM
HTH..
If you are blinding oncoming drivers using your low beams then your headlights are not set properly. They are aimed too high.
I have those LED lights in my car. HUGE difference from the factory ones. Much brighter and a whiter lighter as opposed to that dimmed yellow. Yes they do fan out more which is great - I see more of the road's surface L & R than I did before installing them.
All you do is change out your existing blubs for these new LEDs. HID is much more expensive and more complicated to install.
Old 09-25-2022, 01:22 AM
I think he has stock lights in his truck now and is looking for an upgrade. I installed HID's, complete kit for $88.
The LED's you show above still need the light assembly to install the LED.
The research I did said the quality of the reflector wasn't very good on the 5.75" round bulbs.
I see on google that his truck has the rectangle lights I missed in his post...
Old 09-25-2022, 01:14 PM
Default Headlamps...
Thanks for the info...still a little confused. I looked up the HID products...price point was a lot more than $88.
Found these lamps...are they a consideration?
https://www.topgearautosport.com/170...and-high-beams
https://www.topgearautosport.com/103...ght-conversion
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 09-25-2022, 02:10 PM
Tried doing some research on this for my 68 El Camino (four small round headlights instead of the 4 rectangular on Wilma's 85 GMC).
Could not find one comparison story, written or video, that wasn't put out by a manufacturer, meaning the bottom line is always predetermined.
Looking at these for a total of $400: https://www.headlightexperts.com/low...conversion-kit
Anyone have any experience with this company?
I am assuming I can find LED conversion kits that suck, and others that are fabulous.
Would like to hear from members who have done this on 60s 70s and 80s cars with specific brands. What did you like/dislike?
Old 09-25-2022, 03:49 PM
Old 09-25-2022, 09:53 PM
I can find comparisons for the three different bulbs in modern cars.
I can't find much on classic cars where the entire lamp assembly needs to be swapped out.
