Old 06-21-2020, 01:04 PM
R68GTO R68GTO is offline
Default No damage car trailer tie downs
Planning ahead for when my car will come home with me. I have a 20 ft. enclosed trailer, nothing fancy but it is lacking what I think are adequate tie downs. Obviously I want to be able to safely anchor the car to the floor but also don't want to damage my subframe/axle finishes. Should I install some E-track and use tire straps? What are some recommendations from you guys that do this successfully?
Attachments - The Supercar Registry f6b4a1c7-3146-430f-a47f-cbfdffd775fc._SL300__.jpg f6b4a1c7-3146-430f-a47f-cbfdffd775fc._SL300__.jpg
Old 06-21-2020, 02:51 PM
In my neck of the woods, it is now law to have at least two opposing tires strapped down. You can do all 4 and eliminate the frame straps, but do not use e-track. Install proper D rings that are installed to support the required weight.
Or you can safely use these MACS straps to tow from the frame rails. I've never had a problem using these in the past.
Damien (06-23-2020)
Old 06-21-2020, 03:48 PM
mprice mprice is offline
I pickup the seat belt wraps at Walmart that are covered with sheeps wool, like on the inside of a winter coat. I have never had a problem with them leaving rub marks.
The Following 2 Users Say Thank You to mprice For This Useful Post:
big gear head (06-21-2020), ORIGLS6 (06-23-2020)
Old 06-22-2020, 02:52 AM
flyingn's Avatar
flyingn flyingn is offline
e track and over the tire e track tie downs. No crawling under the car or any straps touching any painted part of my cars. The only way to do it.
Frank Szymkowski
1971 Torino 351c 4v GT convertible. White/white with black,4 speed, shaker, am/fm, ps/pdb, buckets/console, ac, flip headlights
Old 06-22-2020, 07:05 AM
www.autohaulersupply.com all the same equipment
for lower than boutique web site prices.
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
The Following User Says Thank You to CamarosRus For This Useful Post:
R68GTO (06-23-2020)
Old 06-22-2020, 12:46 PM
bergy's Avatar
bergy bergy is offline
I love my E Tracks. If you have cars wider than Camaros - it's a little tough to access the wheels to get the parts secured in my enclosed trailer (at least for an old guy like me!).
Old 06-22-2020, 02:20 PM
DW31S's Avatar
DW31S DW31S is offline
I have loops welded on the frame of the race car and I have axle straps. I use the axle straps instead of the loops so the shocks aren’t tied down with pressure on them while transporting. The straps haven’t damaged any paint on the rear housing or front crossmember. I’m not a big fan of the wheel tie downs because of the skinny front tires, the low pressure rear slicks and the fact that you can’t crisscross to eliminate and sideways motion. Lots of theories on securing a car in/on a trailer, just make sure you choose one that is safe.
The Following User Says Thank You to DW31S For This Useful Post:
Damien (06-23-2020)
Old 06-22-2020, 07:27 PM
I've got 4 sets of these for use through the 4 factory tie down points on FULL FRAME CARS - Vettes large cars ALSO ON THE SUBFRAME on unibody cars with axle straps on the back.
https://www.mfrexpress.com/grade-70/...-grade-70.html
All you really need for a GM is the T hook -
Through the beveled/rolled front slot on the front frame above the sway bar mount on camaros and corvettes and the beveled/rolled slot on the corvette frame in front of the rear wheel.
Old 06-22-2020, 10:23 PM
flyingn's Avatar
Thats where I got my straps.
Frank Szymkowski
Old 06-23-2020, 02:28 PM
napa68 napa68 is offline
My apologies if it seems as though I'm hijacking the thread, but I have a question for you guys.
I have a concern I see with 2nd gen F bodies. I like to cross my tie downs in the front end. It seems like the control arms pinch the axle strap and thus could wear through it. Where are the attachment points you are using?
Thanks,
Tim
Tidmack (06-24-2020)
