Old 03-05-2020, 12:23 AM
luv2sixty9 luv2sixty9 is online now
Originally Posted by big gear head View Post
If it's a 12 bolt Eaton with a '73 date then it would not be an assembly line unit because the 12 bolt was not used after '72.
IDK, it's an original #140 Easton Posi
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
Old 03-05-2020, 02:17 AM
bcmiller bcmiller is offline
Originally Posted by luv2sixty9 View Post
The two that I have listed are loose units that I have lying around, so I don't know what they are out of or the actual date.
I was requesting assistance with the stamped date for the cast dates I know how to read.
Ok - I think you decoded the B 1 G correctly. Not sure on the other.
Old 03-13-2020, 05:10 PM
Verified G is for 1966 from an original 67 Z28.
Old 03-13-2020, 07:04 PM
HuggerSS HuggerSS is offline
Do we know wether “H” or “I” was used for 1968? Mike mentioned that he was not sure if “I” was skipped it the alphabet. Thank you in advance for any clarification!
Old 03-13-2020, 08:17 PM
m22mike's Avatar
m22mike m22mike is offline
Based on post #12 and the photo there of a 1968 unit it looks like ... I....was used. Often times with dates and castings it is not, that is why I said I was not sure.
Mike
Old 06-27-2020, 07:54 PM
I'm going to bring this up again. I've got a 12 bolt 2 series Eaton Posi with a code that looks like A 6 70, but could be A 6 7C. Did they change from a letter code to a number code for the year in '70?
Old 06-28-2020, 02:47 AM
ssl78 ssl78 is offline
I have a 11D of 68 car this is the original posi unit
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
The Following User Says Thank You to ssl78 For This Useful Post:
big gear head (06-30-2020)
  #28
Old 06-28-2020, 02:54 AM
rear end date
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 06-30-2020, 10:31 AM
Thank you SSL78.
That shows I was used for both the month and year.
Old 09-15-2021, 07:51 PM
GotGrunt's Avatar
GotGrunt GotGrunt is offline
I’m bringing this thread back to the top because I need help with a date stamp. It looks to be D 3 D, which would be April 3, but I’m not able to figure out the year.
