Old 06-30-2020, 10:45 PM
Enoch Enoch is offline
Excellent original assembly line installed outside rear view mirror plastic gasket with Camaro script. They do not reproduce this with the Camaro script. $50. Ppff
************SOLD************
Old 06-30-2020, 10:50 PM
Impossible to find 4-speed speedometer cable to body butterfly clip. $150. Excellent original unrestored condition. Ppff ************SOLD************
Old 06-30-2020, 10:53 PM
Two-piece black 4 speed shifter Ball. G stamp on Underside. 5/16 18 thread. $20. Ppff
Old 06-30-2020, 10:56 PM
Original assembly line installed unrestored 837 horn relay. $45. Ppff ************SOLD************
Old 06-30-2020, 11:10 PM
1970 through 72 lower 4 speed cross shaft adjuster Rod. The reproductions are not even close. Excellent original piece. $35. Ppff
Old 06-30-2020, 11:13 PM
Excellent original assembly line installed positive wire to radiator support Junction block and 3 DOT Head marking mounting bolt. Also included the original 10-24 nut with captured washer. $45. Ppff
Old 06-30-2020, 11:35 PM
69 through 74 Big Block 396 427 454 long water pump lower alternator pivot stud with W stamp on end. Very difficult to find Originals. $40. Ppff
Old 06-30-2020, 11:43 PM
Original assembly line installed 68 69 Camaro, Chevelle, Nova washer pump cover with tin foil sticker and made in USA embossed. $30. Excellent condition. Ppff
Old 07-01-2020, 12:59 AM
Original assembly line installed Camaro, Chevelle Nova rear brake line to rear end retaining clip. With manufacturer stamping. Excellent pit 3-piece. $30. Ppff
Old 07-01-2020, 01:01 AM
Original unrestored double pole MB courtesy light switch. Great Survivor condition. $20. Ppff
