Old 02-18-2020, 02:49 PM
m22mike's Avatar
m22mike m22mike is offline
Ken
Nice to see you keeping involved with another cool project, pace yourself and try not to miss any naps
Mike
Old 02-18-2020, 03:27 PM
Z15 SS 454 Z15 SS 454 is offline
Cool Project! I did a 605 box conversion in a 55 Chevy 10 years ago and the factory pitman arm spline does indeed match up.
Here are a few photos of the crude mounting bracket I made to accomplish this.
https://www.yenko.net/forum/attachme...1&d=1582043083
/Users/iancote/Desktop/MVI_0921.AVI
1970 L78 Nova Best ET 9.14@152 MPH Street trim
1970 L34 Chevelle Matching #s Project
1970 LS6 Chevelle Matching #s Project
2001 LS1 Camaro SS SOM Stock
2008 LS3 Sierra Denali Blk Stock
Old 02-18-2020, 07:43 PM
Originally Posted by m22mike View Post
Ken
Mike
And keep those hands clear of any dangers!!
kwhizz (02-18-2020)
  #14
Old 02-18-2020, 07:49 PM
BJCHEV396's Avatar
BJCHEV396 BJCHEV396 is online now
Got my popcorn!
Old 02-19-2020, 12:30 AM
A12pilot's Avatar
A12pilot A12pilot is offline
Sweet! I'm so here, man!!
Cheers
Dave
Old 02-19-2020, 07:16 PM
kwhizz kwhizz is offline
Got the #605 box today…… Pitman arm and the box have the same splines...... Amazingly two of the stock frame bolt holes lined up perfectly ……. I will just need to add 1 hole for mounting...… Got Lucky.....Aftermarket steering column on order along with universal joints allowing for any slight mis-alignment......and after getting the box mounted it looks like we will have room for Headers if required........
The Following 2 Users Say Thank You to kwhizz For This Useful Post:
dykstra (02-26-2020), Xplantdad (02-19-2020)
  #17
Old 02-21-2020, 02:57 PM
The frame is not similar to the normal 55-57 Chevy Frames...… The box is now permanetly.in place...… The upper two mount holes lined up and I was going to drill a 3/4" hole thru the frame and weld in a piece of round rod with a bolt hole in it for the third bolt......After I started drilling the hole with a smaller size drill I noticed there was a frame gusset in the frame....... Ended up I just drilled the hole thru to suit the mounting bolt and everything cleared perfectly right next to the gusset so there was no need to weld the tubing in for support...... Too simple...… Just had to shim the box out about an 1/8" to clear interference between the box and the frame...…..
The Following 6 Users Say Thank You to kwhizz For This Useful Post:
Arrowsmith (02-21-2020), dykstra (02-26-2020), John (03-09-2020), markinnaples (02-21-2020), Xplantdad (02-22-2020), Z15 SS 454 (02-21-2020)
  #18
Old 02-23-2020, 02:22 PM
Did some more disassembly this morning........ Got all the wires that will be replaced with the rewire out...... Removed the make shift trans tunnel ……. There are some rust holes thru the front floor pans so we will be replacing them along with fixing the trans tunnel.....Lot's of parts showing up next week
The Following 7 Users Say Thank You to kwhizz For This Useful Post:
300deluxeL79 (02-23-2020), Arrowsmith (02-23-2020), dustinm (02-23-2020), dykstra (02-26-2020), RPOLS3 (02-26-2020), Xplantdad (02-23-2020), ZAPPER68 (02-23-2020)
  #19
Old 02-26-2020, 02:55 PM
Got the steering column in and got the connection to the box finished ……… Going to put a Patch panel on the Passenger side Floor pan .....… I'll be welding that in today after treating the floor with some Rust remover to get rid of the surface Rust, then treating the floor with Boeshield to help prevent further surface rust...… Engine will be here tomorrow and then the real assy will begin
The Following 5 Users Say Thank You to kwhizz For This Useful Post:
300deluxeL79 (03-08-2020), Arrowsmith (02-26-2020), markinnaples (02-26-2020), SS427 (03-11-2020), Xplantdad (03-08-2020)
  #20
Old 02-27-2020, 11:48 PM
Got the Floor patch panel welded in today and got the drivetrain delivered to the house...… I thought I was going to be able to save Jeff and Judy some $$ by being able to use the as delivered oil pan..…… Wrong...…. Luckily I have a new 302-2 Holley pan in the garage...….. It will have a new home shortly...….
LS3 480H.P. 4L70E trans......
SS427 (03-11-2020), Xplantdad (02-28-2020)
