Go Back   The Supercar Registry > Sponsors > Camaro Nationals- Morgantown, PA
Old 09-17-2021, 09:09 PM
the427king's Avatar
Default 427king find of the day. NO vin ls6 motor just in today !!
complete as shown. all parts came off this motor and are all dated to each other....crv code. no vin or alternate vin. Video available on Facebook on Monday am with all pertinent info. std bore never apart until 2 weeks ago !!!! $15,900
No Fisher priced toys here
Old 09-17-2021, 11:14 PM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Wow!
the427king (09-18-2021)
Old 09-18-2021, 06:38 PM
the427king's Avatar
std bore. std std crank. Original flywheel ,bell housing , timing cover, pan, water pump intake, heads, rods and std 550 pistons. block. etc.
Old 09-19-2021, 01:25 AM
Vortecpro Vortecpro is offline
Your going to be getting out the sleeves on that one, or at least going .070 min.
Old 09-19-2021, 03:07 AM
the427king's Avatar
Ill send your opinion over to the new owner. Thanks .
Old 09-19-2021, 05:08 PM
I often have customers send me blocks with rust pitting, sometimes an over bore will fix the problem, most times it will not get past the pitting. Either way when you need the numbers you could have to fix other problems, thats just the way it is.
The Following User Says Thank You to Vortecpro For This Useful Post:
Copo_Cartel (09-20-2021)
Old 09-19-2021, 06:34 PM
ruralrte66 ruralrte66 is offline
You really find and have alot of neat parts! Very Cool!
The Following User Says Thank You to ruralrte66 For This Useful Post:
the427king (09-19-2021)
