WTB 4.30 or 4.33 12 Bolt passenger car gears any date
Update 10/31 4.33 GM gears found. They sold them over the counter for performance applications. Learned something new!
Update 10/30 Looks like GM did not make 4.30 or 4.33's. So any aftermarket good used gears will be ok. Looking for a good used GM gearset for my car. I want to swap out my 3.55's. Not particular on dates just looking for a reasonably priced original GM set if there is such a thing. Jose Last edited by jbtech; 10-31-2020 at 05:07 PM. |
Freddie will correct me if I am wrong, but I think your options for a correct GM set of gears for a 12 bolt are going to be 3.73, 4.10, 4.56 and 4.88.
Aftermarket makes 4.30 and 4.33 gears. While they were available from the factory in Pontiacs in the late 60s, I think the BOP rear was different from the Chevy 12 bolt.
The Following User Says Thank You to Lynn For This Useful Post: | ||
jbtech (10-31-2020) |
Anyone have some good used gears I won't need to break in? Thanks! |
I have a NOS set of GM 433's (9/39) in the box if interested. There dated 75. Contact me for more info. Larry 5203492337
The Following User Says Thank You to lbnaz For This Useful Post: | ||
Thanks Larry! Jose |
Just for a sanity check there is no part number on the box but the pinion is 3936481 and the ring is 3936482 and both have 9/39. Can someone verify there chevy 12 bolt. I bought them on this site a year or two ago represented as chevy 12 bolt along with other GM gears. Thanks, Larry
I found in the revised special parts book dated 3-9-72 they list part number 3961430 as ring and pinion 4.33:1 ratio Last edited by lbnaz; 10-31-2020 at 06:10 PM. Reason: added info and photos |
Tags |
12 bolt, 8.875, gears, pinion, ring |
Thread Tools | |
Display Modes | |
