RPO-NC8 Hardware. Need help please.
Anybody have a good pic of what the hardware looks like for this exhaust? Been looking at the 69 A.I.M. for installation, and I'm a bit confused on what the screws look like for the hangers and clamps...no dimensions stated. If I can just see them I can go from there. Near as I can tell I need these numbers, 9431541, 9411890, and 3922549 indicated in the A.I.M. RPO-NC8 A1-A3 pages 391, 2, and 3. I'm thinking at least two of those numbers can't be had from AMK or am I mistaken? The pic is what I have now.
Also, the extension, and the packing for the exhaust pipe will most likely be sourced from a muffler shop, correct? #3767555 and 556. These numbers I'm not sure if for BB or SB. I need for SB though. Does anyone use the sealer-grease .50 oz that is indicated? Thanks G.
Gary 06A 1969 X33D80 Z28 Unrestored Last edited by GaryC; 07-31-2020 at 09:26 PM. |
I believe you have listed some of these incorrectly.
943151 should be 9431541 911890 should be 9411890 These have other non-exhaust applications. Someone may be able to get a pic. 3922549 4 B3 rr shock M35 A9 powerglide 9411890 M40 A5 TH400
Thanks William. Yeah, I have a '4' that needs slamming every once in a while. I fixed the part numbers. 3922549 I'm thinking those 2 black ones are for the over the axle muffler bracket. AIM says two ea for the standard system hangers, and one ea for the chambered hangers. And the zinc colored ones are for the hangers attached to the frame rails for the tailpipes. Still...there is the round clamp #7, pg 391 in the AIM, item #6 , and tailpipe hanger #4, page 392, item #3. These two I'm unsure of what they look like if I need an alternative.
Gary 06A 1969 X33D80 Z28 Unrestored Last edited by GaryC; 08-05-2020 at 03:37 AM. |
That grease is high temp clear silicone. Here’s a pic of my nova hardware.
What are those inserts for John?
Gary 06A 1969 X33D80 Z28 Unrestored |
Well nuts. They go into the rear of the floor board. 69 Nova has 3 for each hangar. Camaro has 2. If your car has Factory dual exhaust they are already in place. If not there are dimples there and you drill them out and put in the special nuts. Just so happens my amk package came with them. But the car has them installed from the factory.
Yeah, I have the standard system hanging now getting ready to pull it out. Trying to get the hardware sorted out to install the chambered system this fall maybe.
RIV NUT = Steel or Other metal clinched threaded inserts. (Console & Exhaust)
WELL NUT = Rubber encased Nut (Radiator or Voltage Reg) Jim
69 Los Z11 68 SS/RS 396/325 68 Los Z28 |
The Following User Says Thank You to 169indy For This Useful Post: | ||
GaryC (08-02-2020) |
Hope this helps others. Did a little digging this A.M. and found something that looks to be close. (From research off T.C.) Looks like too much hardware for chambered system though. It's amazing the brackets that bolt up to the floor bottom only require one bolt. Now I just have to figure out where that bolt goes. The AIM is unclear, at least seeing it on paper.
Gary 06A 1969 X33D80 Z28 Unrestored Last edited by GaryC; 08-02-2020 at 09:03 AM. |
Bolt goes through one of the metal brackets in the middle of your photo then through the over axle strap and into the floor pan - - orient the metal re-enforcement with the TAB pointed towards the floor boards (UP) The TAB acts as interference against the floor pan so you do not over tighten the strap -
~JAG~ NCRS#65120 68 GTO HO 4 spd Alpine Blue /Parchment 2 owner car #21783 71 Corvette LT1 45k miles Orig paint - Brandshatch Green - National Top Flight - last known 71 LT1 built. 71 Corvette LT1 42k miles Original paint - Black - black leather - only black LT1 known to exist. NUMEROUS Lemans blue Camaros, Monza Red and Daytona Yellow Corvettes & a Chevelle or two... Survivors, restored cars, & other photos https://picasaweb.google.com/lh/myphotos |
Thread Tools | |
Display Modes | |
