Old 11-14-2019, 10:40 PM
Enoch Enoch is offline
Mid 63 through mid 66 small block steel valve cover mounting bolts. R in a circle head marking. Excellent original pieces; unique 3/8 hex design. Very hard to find. $40. (X2)
**********SOLD**********
Old 11-19-2019, 07:36 PM
Cowl inuction air cleaner card studs. 4 excellent original cold rolled steel studs with dimple on end. $50 each. PPFF
************SOLD************
Old 11-20-2019, 10:07 PM
Sold
Old 11-20-2019, 10:10 PM
Very nice complete restored set of small block oil pan mounting bolts. S in circle head marking for the 14 side rail bolts and E in circle head marking for the 4 corner bolts. These head markings were generally used in late 1970 on up. $35. PPFF (X2)
Old 11-22-2019, 09:58 PM
Heater hose clamp. 4 1/2 stamp, $40. Excellent condition. (X) PPFF
Old 11-22-2019, 11:01 PM
Excellent original set of 65 to 68 small block and big block alternator pivot bolts. The lower bolt has O for its head marking the spacer is F stamped and it has it's 2 small outside diameter flat washers one lock washer and nut. The top bolt has SBC for its head marking large oversize flat washer and lock washer. As nice as you will ever find. $50. PPFF. (X)
Old 11-23-2019, 11:33 PM
Original assembly line installed block drain plugs. Correct 9/16 Hex with dimple. $20. PPFF
Old 11-24-2019, 11:26 PM
NOS small block oil pump and pick up a. Original GM piece that was purchased 40 years ago and been sitting on a shelf. $35 plus $10 to ship. PPFF. (X)
Old 11-25-2019, 07:45 PM
Original re plated cowl induction hood coil bracket and screw.$30. PPFF (X) ***********SOLD***********
Old 11-25-2019, 09:52 PM
Tri-power secondary vacuum advance lines. Original white stripe and original translucent vacuum T. As nice as your going to find.
Also correct for A.I.R. spark advance/take off $60. (X) ***********SOLD************
