Clips, clips, brackets.....and more clips
Starting a post to list some of the thousands upon thousands of clips and small brackets that I have. Some of them I know what their application is, a lot of them I don't. 99% of this stuff came out of shops that worked strictly on mid 60s through early 70s GM cars. Will price most everything to move quickly. Please make sure to include the post number in your request. If there's a clip that you want but don't see, send a picture and I may have it.
Really nice original set of oil pan side rail mounting clips. These clips hold cables and lines.$15 each. PPFF I have several sets available.
***ALL SOLD WILL GET MORE OUT AND REPOST*** Last edited by Enoch; 10-29-2019 at 11:51 PM. |
These clips attach to the bolt that mounts the transmission to the Bell housing and holds either wires or speedometer cable.$15 each PPFF
The mounting hole uses a 7/16 thread bolt. These clips are $15 each. PPFF
These clips have a 3/8 mounting hole and will bolt to the bell housing to block mounting location.$15 each. PPFF
Big block valve cover retainer / wire loom.Very nice original piece. $30. PPFF
************SOLD************ Last edited by Enoch; 01-17-2020 at 06:49 PM. |
Antenna cable to inner rocker rail mounting clip.$20 PPFF
These clips have a 3/8 mounting hole and vulcanized coating on them. $15 each. PPFF
Reverse light / TCS solenoid wire harness mounting clip. This clip mounts on one of the transmission to bell housing attaching bolts. $25 PPFF
***********SOLD************ Last edited by Enoch; 10-30-2019 at 06:36 PM. |
Rich, can I get the reverse light mounting clip?
Also, fyi for all the rocker rail mounting clip isn't reproduced that I could find. For $20 that's a great deal. |
The Following User Says Thank You to Hrlyfxdl For This Useful Post: | ||
Enoch (11-01-2019) |
