Old 06-21-2023, 07:36 PM
jbtech's Avatar
jbtech jbtech is offline
I found a correct original takeoff driveshaft that was painted decades ago and it's staying that way. In fact I've been very fortunate to find some very hard to find goodies for the car.
Bill James Muscle car factory has my vert MQ block and it's being built. For now my 462 with 3521 crank, 077 heads, 198 intake, and straub roller cam will go in the car.
I'm running a 70 Chevelle M22 so I'm going to use a different yoke to work with the setup. I found a yoke that is 1/2" longer than original so I'll have the machine shop turn it to the correct factory length.
I'm using Crash's custom shifter mount that will allow the shifter to pivot into correct position and accommodate the offset of the big block crossmember. The shifter is a first generation hurst setup with the early fat letter stick. I will need to gently grind off a portion of the reverse lockout for it to fully disengage as it interferes with the shifter mount, so for now I'll go without it.
I was able to find an excellent condition original black dash pad and got it installed. Unfortunately, I found a factory flaw where the dash was installed about a 1/4" higher up on the LH A pillar vs the RH side so I'm fighting to get the LH a pillar molding fitted.
I prepped the windshield channel for glass and had a local installer get it done. I decided to go with urethane as I feel it helps improve the integrity of the body. The install is guaranteed leak free for life. I bought tinted glass with date NZ (January 1967) This matches the date of the back glass. All glass on the car is original with exception of the windshield.
I continue to speak with the original owner Bruce Cremean weekly. Judy Rooker who owned the car from the 80s-2000s promised she'd reach out to my in July and find photos etc of the car. She took it to prom and her HS boyfriend installed these wild rear flares. She is also the last known person with the muncie so hopefully something comes from that.
Unfortunately, I haven't had a reply in my last two attempts to keep in contact with the folks with the original engine although one is a "friend" on FB can can see my posts. I still have hope something can be worked out that makes both parties happy but for now I think I just need to leave them be.
Jose Betancourt
67 Camaro L78
The Following 12 Users Say Thank You to jbtech For This Useful Post:
1967Z28 (06-22-2023), 69M22Z (06-21-2023), big gear head (06-21-2023), Copo_Cartel (07-30-2023), dykstra (06-23-2023), juliosz (08-01-2023), L78M22Rag (07-06-2023), L_e_e (06-21-2023), olredalert (07-06-2023), PeteLeathersac (06-22-2023), R68GTO (06-22-2023), Too Many Projects (06-21-2023)
  #182
Old 06-22-2023, 03:47 AM
luzl78 luzl78 is offline
Jose, where did you buy your glass from? Jeff
Old 06-22-2023, 04:01 AM
Looking Great JB! I love that driveshaft. I bet it feels great to have the windshield back in. Great work!
Jason
jbtech (06-22-2023)
  #184
Old 06-22-2023, 04:59 AM
L72copocamaro L72copocamaro is offline
Love the driveshaft and would leave it as is too!
The Following 2 Users Say Thank You to L72copocamaro For This Useful Post:
jbtech (06-22-2023), L_e_e (06-22-2023)
  #185
Old 06-22-2023, 05:06 PM
jbtech's Avatar
Auto City Classic
Ebay Item #: 302654318337 for the tinted glass.
When purchasing I sent a PM with the date I wanted in the glass.
Jose Betancourt
67 Camaro L78
The Following User Says Thank You to jbtech For This Useful Post:
luzl78 (06-22-2023)
  #186
Old 06-22-2023, 11:31 PM
Might want to compare the cost, buying direct. They are paying ebay fees...
https://www.autocityclassic.com/camaro-glass/
1964 Chevelle SS was 230 6 cylinder
jbtech (06-23-2023)
  #187
Old 06-23-2023, 12:24 AM
I just ordered one for my 70 Monte. Original green tinted glass and stamped and dated. It was $424 shipped
Old 07-05-2023, 08:50 PM
jbtech's Avatar
I rebuilt the internal mechanisms for the LH door glass and LH quarter window, installed a new vent window channel as the Old one was destroyed. The glass was banging around getting scratches over the years. I used a bolt in style roller to replace the busted large roller. Jesser's classic keys rebuilt my lock cylinders and they also made keys stamped to match which is cool because the key codes are original to the sales documentation. I adjusted the door and it no longer needs to be slammed shut. A gentle push and it catches. This is with original door hinges so I'm happy.
I installed the water shields and didn't forget to tuck them in at the bottom. After that I installed the door panel with the handle springs in between the panel and mechanism.
Door panel, handles, handle washers, arm rest are all original gm. I can see the light at the end of the tunnel.
Jose Betancourt
67 Camaro L78
The Following 18 Users Say Thank You to jbtech For This Useful Post:
1967 4K (07-05-2023), 1967Z28 (07-06-2023), 69M22Z (07-06-2023), big gear head (07-24-2023), Chuck_Burg (07-05-2023), Dave Rifkin (07-06-2023), dykstra (07-10-2023), John (07-10-2023), juliosz (08-01-2023), L78_Nova (07-05-2023), L_e_e (07-05-2023), olredalert (07-06-2023), PeteLeathersac (07-06-2023), RPOLS3 (07-06-2023), scuncio (07-24-2023), Steve Shauger (07-06-2023), SuperNovaSS (07-06-2023), Too Many Projects (07-05-2023)
  #189
Old 07-24-2023, 06:04 AM
jbtech's Avatar
Disassembled, cleaned, and reassembled the original cluster assembly. A little over 97K original miles.
I swapped the black housing to a better condition spare original gm one I had on the shelf. I also swapped the circuit board as the original was fried. I installed all new bulbs and can't wait to see it lit up.
Jose Betancourt
67 Camaro L78
1967Z28 (07-24-2023), 1crossram (07-24-2023), 69M22Z (07-28-2023), big gear head (07-24-2023), dustinm (08-02-2023), dykstra (07-24-2023), juliosz (07-24-2023), olredalert (07-24-2023), PeteLeathersac (07-24-2023), RPOLS3 (07-24-2023), Steve Shauger (07-24-2023), SuperNovaSS (07-25-2023)
  #190
Old 07-27-2023, 08:03 PM
jbtech's Avatar
Original GM dash switches installed. I sorted through a box, weeding out any damaged bezels or repop parts. The lighter is NOS. The ignition switch is the original coded "born with" rebuilt assembly. I used the specialized tools to reinstall without damage.
Jose Betancourt
67 Camaro L78
The Following 7 Users Say Thank You to jbtech For This Useful Post:
1967Z28 (07-29-2023), 69M22Z (07-28-2023), big gear head (07-27-2023), Copo_Cartel (07-30-2023), dykstra (09-27-2023), scuncio (07-27-2023), Too Many Projects (07-28-2023)
Tags
1967, 396 ss, l78 camaro
Copyright ©2000 - 2023, vBulletin Solutions Inc.
