Old 07-22-2019, 07:57 PM
dmarr35 dmarr35 is offline
Default from a 12" flexplate to a 14"
I have a 1969 427 with a th400 it had a 12" 3 lug converter I want to change t a 6 lug 14" flexplate can I do this and if so what about the starter? Thank You
Old 07-22-2019, 08:38 PM
I think I just have to go to a staggered bolt starter
Old 07-23-2019, 12:10 AM
John Brown's Avatar
Yes. Common aluminum snout starter is industry number 3510, industry number for iron snout starter is 3689.
John Brown
Old 07-23-2019, 12:29 AM
John Brown's Avatar
And.... when you buy your new starter, may as well buy the correct bolts to mount it with. No reason to cheap out now.
John Brown
Old 07-23-2019, 10:04 AM
Thank You
Old 07-23-2019, 12:52 PM
earntaz earntaz is offline
So true -- you're not going to believe how many times I have seen Pick-a-Nut bolts used to bolt on starters and the owner can't figure out where all the racket comes from along with tore up ring gear ... TAZ
