Old 06-17-2015, 08:33 PM
1968BM 1968BM is offline
Send a message via Yahoo to 1968BM
Default Re: Cowl induction seal
Ill turn the seal inside out and check it tonight. Thanks 70
1968 Chevelle
427 BBC
Muncie 4 speed
Rats Rule
Old 06-29-2015, 03:41 PM
SOM2001SS's Avatar
SOM2001SS SOM2001SS is offline
I am definitely marking this to reference if I ever get around to installing the correct air cleaner assembly on my Chevelle.
1970 Chevelle SS454 Fathom Blue, 01 Camaro SS Sunset Orange Metallic, 65 Plymouth Belvedere vert
Old 09-03-2015, 10:24 AM
DW31S's Avatar
DW31S DW31S is offline
Great info.! Thanks! Mike, when your post mentioned "training the seal", I wondered if we were to see a video from SeaWorld?!? Just jabbin' atcha!!! Really good info and it is surprising to see some nicely restored cars with the seal installed incorrectly.
Old 11-22-2015, 12:16 PM
Starship Starship is offline
Shouldn't an original seal have ribs around the circumference?
Old 03-01-2016, 03:28 PM
SS454Elky SS454Elky is offline
Send a message via ICQ to SS454Elky
This is a very timely topic as I just installed a repo unit on my camino this weekend. What is the orientation for the flange on the air cleaner? I assumed the flat section of the flange was there to clear the distributor, but I notice in the picture attached to this thread that the "Rear" sticker was aligned with the flared section of the flange which would place the "flat" over near cylinders 4 and 6. How in the heck is the flange supposed to be oriented?
Thanks,
Jon
Old 03-01-2016, 03:53 PM
SS427's Avatar
SS427 SS427 is offline
The flat section on the flange ring is to clear the A/C unit on Chevelles. The flared section of the ring will go in the rear and corresponds with the indented area of the air cleaner which is for distributor clearance. Also that is where the "rear" decal is. The flat section would be in about the 10 thru 11 position on the clock. Hard to see in this photo but you can see where the rubber seal is out of round in that area due to the flat spot in the ring. Most people say the tape seam should be in above the "rear" decal but I have found them all over the place and I will normally put them exactly how I found them if it is the original seal and ring.
Rick Nelson
Old 03-01-2016, 04:23 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SS427</div><div class="ubbcode-body">The flat section on the flange ring is to clear the A/C unit on Chevelles. The flared section of the ring will go in the rear and corresponds with the indented area of the air cleaner which is for distributor clearance. Also that is where the &quot;rear&quot; decal is. The flat section would be in about the 10 thru 11 position on the clock. Hard to see in this photo but you can see where the rubber seal is out of round in that area due to the flat spot in the ring. Most people say the tape seam should be in above the &quot;rear&quot; decal but I have found them all over the place and I will normally put them exactly how I found them if it is the original seal and ring. </div></div>
Ahhhh the AC box. that makes perfect sense. My car does not have AC so I didn't think about that. I thought the flared section should go to the back, but the flat confused me. All clear now. Thanks!
Old 05-20-2018, 03:14 AM
Digging up an old thread here. On the 69 Z that I am working on, I pulled the flange off to install a new seal. The flange has a GM sticker on it, but it isn't exactly like the original on my car. Mine is not perfectly round, a a small part on the passenger side is slightly egg shaped. BUT mine still has the little 90 degree lip all the way around. This one just has that part cut off, so there is no lip to hold the seal.
Hope that makes sense. can post pics tomorrow.
So, two questions.
1. Are all the over the counter NOS flanges like that?
2. How to you get the new seal to mount correctly? Glue?
Thanks for any help.
Old 05-20-2018, 03:18 AM
I THINK I just found the answer. The 70 Chevelle flange has a that part cut out.
http://www.camaros.net/forums/34-res...lots-pics.html
Post #2
Anyone have a GM Camaro flange that you want to trade for a 70 Chevelle GM (with the sticker) NOS flange?
Old 05-20-2018, 11:29 AM
KevinW KevinW is offline
Lynn, glad my old thread was helpful!
The cowl seal should not need any glue, the tension alone should keep it in place. Have you seen my cowl seal instruction thread?
http://www.camaros.net/forums/34-res...tions-zl2.html
69 327 convertible (driver)
