#71
Original assembly line installed restored power steering hose to frame mounting clip the reproductions have different shaped ridges and they do not have the original C stamped on them. Very nice very hard to find. $100
#72
Extremely nice original Three. Raised Circle power brake booster check valve. You won't find a nicer one that is not chalked or discolored. $100
#73
68 through 72 three-quarter inch hole posi traction label and plug. Very hard to find. SOLD $125 SOLD
#74
Does the plug have the letter W in it?
#75
Rick, no I'm out of plugs with W with the line underneath it at the moment. And this one just sold about 2 minutes ago.
#76
67 through 69 Camaro Firebird rear pinion rubber snubber. Push and style that mounts to the floorboard bracket just above the pinion. Very hard to find Originals. SOLD $100 SOLD
#77
67-69 Camaro Firebird rocker panel drain flap. $40.
#78
I have 7 NOS yellow painted 1157 marker light bulbs. Very difficult to find and must be used on the front parking lights with clear lenses. These are the original assembly line installed painted pieces not yellow colored glass. $20 per bulb
#79
Rally sport headlight Parts removed from a very low mileage 67 pace car over 25 years ago. Included are four original Brown Bakelite limit switches. These are very different than the current reproductions. They all still have their original cloth tape on them. Also included is an original dated 10 amp Buss fuse with its red inspection Mark and date coded 02 7. Also included is the mounting hardware for the relays to the control plate and the two screws for the number 10 fuse. $100. Again very nice very hard to find parts.
#80
Camaro Chevelle Nova Corvette firewall insulation rubber plugs. 5 included in this set. These were removed from a 69 Camaro 25 years ago. $45
