Old 02-14-2020, 10:10 PM
Enoch Enoch is offline
Camaro Chevelle Nova Impala GTO re stored ground strap mounting bolts. 4 different sets. RBW, domed (with or without circles) and D. $30 a set. *****SOLD*****
Old 02-16-2020, 06:15 PM
Original rallisport headlight doorstop bracket (GT stamped) with mounting Bolt (L headmarking) and rubber grommet. $35 PPFF ************SOLD************
Old 02-19-2020, 09:25 PM
Original double crimp battery hold down clamp. Found this one sitting in a bin that I hadn't looked in for many many many years. I actually had this replated about 20 some years ago. Very very nice just some minor pitting on the 1 side and I mean minor. With C stamping. $80
Old 02-19-2020, 09:37 PM
HuggerSS HuggerSS is offline
Rich, I will take the battery hold down clamp. Paul
The Following User Says Thank You to HuggerSS For This Useful Post:
Enoch (02-19-2020)
  #35
Old 02-19-2020, 09:40 PM
Paul, thanks I'll send you a PM with payment info. Rich
Old 02-24-2020, 05:53 PM
Excellent original restored fire wall to hood ground clip and mounting bolt. Clip has C stamped on it and the ground bolt has an anchor had marking. $40 PPFF *****SOLD*****
Old 02-24-2020, 08:03 PM
2 excellent restored battery cable clips. These attached to both the alternator bracket and the sub frame and frames. Very hard to find good originals. One has most of its vulcanising on it and the other 1 has it all stripped and needs to be dipped again. But these are in really nice condition. $35 each. Or $60 for both PPFF *****SOLD*****
Old 02-24-2020, 08:20 PM
PM sent
Enoch (02-24-2020)
  #39
Old 02-24-2020, 08:49 PM
Very nice pair of original restored washer nozzles squirters for 67 through 69 Camaro. Also included are 2 original C head marking mounting bolts. $40 PPFF *****SOLD*****
Old 03-01-2020, 09:54 PM
Excellent original unrestored 30 amp little bus fuse circuit breaker for power windows and power convertible tops. Included are 2 original GL head marking mounting bolts, 2 NOS 10-24 well nuts and 2 original green insert locknuts. As nice an original setup as you're gonna find.$50. PPFF X
