Old 10-14-2019, 08:55 PM
Enoch Enoch is offline
Original shifter rod adjusters.$35. PPFF
************SOLD************
Old 10-14-2019, 09:21 PM
Contents of case includes several hundred small parts, mostly brand new for rebuilding transmissions. Some used original pieces are included such as the detent levers (2 sets) and reverse lever extender. New items are front bearing cage retainers, half a dozen brand new shifter shaft seals, one NOS speedometer adapter seal, clutch fork slider keys, spacers, O rings, roll pins and several sets of needle bearings, both large and small, and front cage bearings, thrust washers, gear retainers, idler thrust washers. $75 PPFF
Old 10-14-2019, 09:40 PM
16 brand new large output shaft rear seals. 10 brand new large output shaft rear bushings and 4 brand new small output shaft rear bushings. $ $40.
Old 10-14-2019, 11:57 PM
dvss1 dvss1 is offline
If the gto levers are still available, I will take them.
The Following User Says Thank You to dvss1 For This Useful Post:
Enoch (10-14-2019)
  #15
Old 10-14-2019, 11:59 PM
They are yours. I will mark them sold and send you a private message with payment information. Thanks Rich
Old 10-17-2019, 11:20 PM
Original restored Muncie side cover mounting bolts; UR head marking. $35 PPFF (X2-EDTA) **********SOLD**********
Old 10-17-2019, 11:25 PM
Original restored Muncie side cover mounting bolts; L head marking. $35 PPFF (X2-EDTA) **********SOLD**********
Old 10-17-2019, 11:26 PM
Original restored Muncie side cover mounting bolts; NAT head marking. $35 PPFF (X2-EDTA) **********SOLD**********
Old 11-06-2019, 11:49 PM
NOS Hurst shifter parts kit. Part number 154-0110 been laying around for 30 some years. New ones are $30. $15 PPFF
Old 12-02-2019, 09:43 PM
All remaining items in this thread listed prior to 11/30/19 are now 30% off ....FOR THIS WEEK ONLY! On 12/10/19, the sale ends ... Thanks for looking!
