Old 04-15-2021, 12:36 AM
Enoch Enoch is offline
Original assembly line installed big block (short) dip stick tube. $100 PPFF (852) ************SOLD************
If you're looking for original hardware you can call or
text 610 462 4441...
Or email [email protected]
*****WANTED ORIGINAL HARDWARE*****
Looking for any and all original Hardware from GM cars. Engine bolts, body bolts, chassis bolts. I will buy it by the bucketful or drum full. Check out our YouTube channel! https://www.youtube.com/channel/UCVy...32gj-TSqd3l_ig
Thanks, Rich
Old 04-15-2021, 06:14 PM
Very nice original unrestored Camaro Chevelle Nova rear license plate light assembly. The reproductions don't have the right color screws with the right configuration etc etc. $40. Ppff (853)
Thanks, Rich
Old 04-15-2021, 06:22 PM
Very nice unrestored solenoid harness clip with Loop. $45. Ppff (854) ************SOLD************
Thanks, Rich
Old 04-15-2021, 06:31 PM
M68-74 396 427 454 2 bolt main oil pressure to block brass fitting. This one still has the original sender for cars with idiot lights. Perfect greasy grimy for a Survivor or will clean up nicely. Has WEATHERHEAD stampings. $60 PPFF (855) ***SALE PENDING***
Thanks, Rich
Old 04-15-2021, 06:38 PM
M68-74 396 427 454 2 bolt main oil pressure to block brass fitting. Also included are the NOS Adapter and 5/16" hex swedge lock. Has WEATHERHEAD stampings. $75 PPFF (856)
Thanks, Rich
Old 04-18-2021, 10:24 PM
ABSOLUTELY MINT UNRESTORED Z28 LT1 Aluminum Valve Cover Bolts. Just pulled these out of tons of parts I went through on friday at an old Corvette junkyard. $150 PPFF (857)
Thanks, Rich
The Following User Says Thank You to Enoch For This Useful Post:
Tracker1 (05-14-2021)
  #17
Old 04-18-2021, 10:27 PM
4 VERY nice Survivor Z28 LT1 Aluminum valve cover bolts. $60 PPFF (858) ************SOLD************
Thanks, Rich
Old 05-04-2021, 05:35 PM
Hydraulic lifter Big Block PCV Hose to intake manifold clip w/D stamping. $50 PPFF (859)
Thanks, Rich
Old 05-04-2021, 05:58 PM
Excellent set of original unrestored tapered and dimpled carb studs with square-edged tall mounting nuts. $80. Ppff (860)
Thanks, Rich
Old 05-04-2021, 06:18 PM
Excellent unrestored heater hose to alternator bracket retaining clip and mounting bolt. This clip is probably one of the nicest Survivor clips and bolts I've had. Perfect for a Survivor or will restore as nice as you've seen. With AS stamping and E head marking Bolt. $45. Ppff (861) ************SOLD************
Thanks, Rich
Hrlyfxdl (05-05-2021)
Copyright ©2000 - 2021, vBulletin Solutions Inc.
