Old 05-20-2014, 10:45 PM
Default what transmission is this???
buddy has a muncie transmission for sale.
3925660 is a number on the side.
u.s patient 3088336.
just curious is this thing is a m-21, m-22 or a 20.
the guy claims is came out of a 70 camaro.
thanks owen.
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
Old 05-20-2014, 10:55 PM
x77-69z28's Avatar
Default Re: what transmission is this???
Need the stamping numbers off the case. If I'm not mistaken, the 661 case was 70 and up. The M-20 and 21 use the same case, m-22 had a drain plug. Should be a partial vin stamped by the trans stamp.
Old 05-20-2014, 11:12 PM
there is a "p8a" stamped on the mid plate.
then a "2 12 " on the side on the main case. thats all i have from the picture i took.
Owen Simpson
Eric Simpson
Old 05-20-2014, 11:50 PM
Fast67VelleN2O's Avatar
All 661 cases had the lower drain plug so that won't tell you it's an M22.
Day 2 is Life.
Old 05-21-2014, 12:12 AM
crash crash is offline
660 Main cases were used in Aug. and part of Sept. of 1969, the beginning of the 1970 model year, and these have drain plugs...
Thats one of the model year changes, beginning of the 1970 model year all Muncie main cases are drilled for fill and drain plugs...
Hope this helps... Crash
Old 05-21-2014, 12:14 AM
If the trans was original to the 1970 Camaro it would have a 661 main case... Crash
Old 05-21-2014, 04:37 AM
Kurt S Kurt S is offline
Sounds like a 68. But you're missing some #'s.
http://www.camaros.org/drivetrain.shtml#trans
Kurt S - CRG
Old 05-21-2014, 11:18 AM
i might have to have a look at it again. and look at it more closely.
It looks to be average shape.
Whats a tranny worth with the bel housing? 200$?
Owen Simpson
Eric Simpson
Old 05-21-2014, 03:28 PM
x77-69z28's Avatar
They are going for more than that. I would say around $5-600.
Old 05-21-2014, 06:25 PM
so there is no way by looking at the "numbers" on a tranny like this to determine if its a M-20 or M-21?
Owen Simpson
Eric Simpson
