Stencil Kits
We’re getting closer to paint on the 67 Z. Does anyone have a recommendation on a stencil kit for the stripes?
Thanks Paul |
Thanks Lee, have you used this kit?
Progress PICS!!!!!
Stencils & Stripes Is who I've used with good success....Joe
The Following User Says Thank You to X66 714 For This Useful Post: | ||
juliosz (10-31-2022) |
Like Joe, I would recommend Stencils & Stripes in Illinois. I bought their kit for my 69 Z/28 and it was identical to all the original tracings I took from the car's original paint marks. Excellent templates in my opinion.
https://www.stencilsandstripes.com/p.../model/camaro/
I like solid lifter cars, big cams and cars w/ 3 pedals in them. |
The Following 3 Users Say Thank You to NorCam For This Useful Post: | ||
This is about three weeks ago. They since primed again and final sanding prior to going back on the rotisserie.
The Following 9 Users Say Thank You to juliosz For This Useful Post: | ||
169indy (11-01-2022), 1967Z28 (11-04-2022), Lee Stewart (11-01-2022), napa68 (11-01-2022), NorCam (11-01-2022), olredalert (11-01-2022), PeteLeathersac (11-04-2022), RPOLS3 (11-01-2022), X66 714 (11-01-2022) |
That is who I used for the stencil kit on my 69 Z, and like Norcam said, it was dead on.
The Following User Says Thank You to Lynn For This Useful Post: | ||
juliosz (11-01-2022) |
I have a kit on order from Stencils and Stripes. Many thanks for all of the advice and support from the fine folks on this forum!
The Following User Says Thank You to juliosz For This Useful Post: | ||
X66 714 (11-04-2022) |
The '67-'68 is obviously a little different in the back compared to a '69. I had a Stencils & Stripes kit and found I had to fudge around a little to get it to look accurate and how I wanted it. I did have an original paint '67 Z trunk lid to help get the spacing right. I mounted that lid and masked the filler panel below the rear window and then mounted the lid I was going to use. I then masked that lid following what was above. The original stripes are slightly narrower at the back edge than up toward the window if I remember correctly.
Thread Tools | |
Display Modes | |
