Old 06-14-2022, 08:17 PM
camarojoe's Avatar
Originally Posted by flyingn View Post
https://www.castrol.com/en_us/united...x-classic.html
$20 for 5 quarts at my local Walmart
Seems like a game changer to me.
Joe Barr
The Following User Says Thank You to camarojoe For This Useful Post:
earntaz (06-14-2022)
  #12
Old 06-14-2022, 08:51 PM
x33rs x33rs is offline
I'd like to see someone using it with an oil analysis. But it sure sounds nice.
The Following User Says Thank You to x33rs For This Useful Post:
  #13
Old 06-14-2022, 10:17 PM
Tidmack Tidmack is offline
I also use the Valvoline VR1 line, and they have a 20W-50 viscosity if you choose, too. I can't speak to using synthetic in a recent rebuild, but I tried synthetic in two of my older cars years back and neither liked it much. Same viscosity as dino oil, but both vehicles started burning oil with the Castrol Syntech I used, so I suspended use. Other folks may have different experiences, but I'll stick with with VR1.
Jeff
Originally Posted by X66 714 View Post
I use Valvoline VR1 10w30 & a Wix 1st line oil filter. The VR1 is high in ZDDP....Joe
The Following 2 Users Say Thank You to Tidmack For This Useful Post:
earntaz (06-14-2022), ScottG (06-19-2022)
  #14
Old 06-15-2022, 03:27 AM
tjs44 tjs44 is offline
I use 10-30 Mobil 1 in all roller and hyd roller cam cars as it comes out of the bottle.No additives.Tom
The Following User Says Thank You to tjs44 For This Useful Post:
earntaz (06-15-2022)
  #15
Old 06-15-2022, 01:12 PM
GearheadSS's Avatar
GearheadSS GearheadSS is offline
I've used Valvoline VR1 and Lucas Hot Rod & Classic oil. No complaints with either.
The Following User Says Thank You to GearheadSS For This Useful Post:
  #16
Old 06-18-2022, 02:15 PM
Just bought 5 Quarts of the Castrol GTX Classic at a local Walmart for $6.28 a qrt. sold in Quarts only. Thought I give it a try when changing the oil in the fall. I have been using VR1 for a number of years.
The Following 2 Users Say Thank You to Mr.Nickey Nova For This Useful Post:
camarojoe (06-19-2022), earntaz (06-19-2022)
  #17
Old 06-18-2022, 11:09 PM
RALLY RALLY is online now
I like Valvoline VR1 10w30 Conventional oil with a Bosch oil filter. Would like to try Quaker State 5W-30 full synthetic oil. From what i am told, this oil is the best on the market from an engineer who tests motor oils. But full synthetic oils have be known to cause oil leaks on older engines and sometimes tappet ticking when starting up engine after sitting and then stop after lifters pump up.
The Following User Says Thank You to RALLY For This Useful Post:
