Go Back   The Supercar Registry > Comments/Suggestions > Comments, Suggestions, Problems
Old 11-30-2013, 10:00 PM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Default HTML link codes in post
A couple of times, I've added link codes in a post, using HTML code such as this. If I preview the post, the hyperlink appears and works, but when I submit the post, the HTML code is displayed instead of the link. Then I can't edit the original, as the post editing time has expired. What gives?
Tim in NSW, Australia
Old 12-04-2013, 11:49 PM
SD's Avatar
SD SD is offline
Administrator
Default Re: HTML link codes in post
this
add 'http://' in front of it
<div class="ubbcode-block"><div class="ubbcode-header">Code:</div><div class="ubbcode-body ubbcode-pre" ><pre>
this
</pre></div></div>
Old 12-05-2013, 07:11 PM
ZLP955's Avatar
Great, thank you!
