Tire question
So my 69 RS Camaro is a factory rally wheel car. This is a 307 car. What do you think would have been the tires white stripe or white letter?
Car is code 50 Dover white with black houndstooth gut.
Chris Slawski 69 Nova 69 Malibu 69 Camaro RS 69 Camaro SS 396 |
Your car would've came with E78-14 black wall tires with an option for white walls. White walls were popular then. Of the 243,085 Camaros built it look like 138,160 had some sort of white/red pinstriped tire or white walls. I see no option for white lettered tire in that size for 1969. I got this information from Camaro Research Group in the option section...Joe
The Following User Says Thank You to X66 714 For This Useful Post: | ||
chris slawski (12-30-2019) |
Hi Chris I found some vintage ads for the 1969 Camaro
model year and it appears that one photo does show that the car is equipped with Firestone RWL Wide Oval F70-14's. Not sure if it matters but all 3 pics are non high-performance cars. The convertible has what looks to be a 3/4" or 1" white stripe with steel wheels and wheel covers. I understand that you have factory rally rims but in my opinion both these tires would look good on any wheel (steelie or rally). Good luck. Sal
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys. |
Were any 69 Camaros actually delivered with Firestone Wide Ovals? I have 5 F-70-15 that still have the stickers on them. After I bought them, I thought it was determined that Wide Ovals never came on 69 Camaros, so I never put them on my car.
The Following User Says Thank You to Unreal For This Useful Post: | ||
chris slawski (12-31-2019) |
F70 x 14 yes; F70 x 15 no.
Originals were small RWL; all current repros are incorrect. |
The Following User Says Thank You to William For This Useful Post: | ||
The Following User Says Thank You to Mr70 For This Useful Post: | ||
Thanks folks! I have a set of white stripe 205 75 14 radials heading my way...pictures to follow...of course!
The Following User Says Thank You to Lee Stewart For This Useful Post: | ||
