Old 10-12-2018, 01:47 PM
Tracy Weaver does amazing Work :-)
Well done!
Old 10-12-2018, 06:14 PM
Cool!
Old 12-10-2018, 10:57 AM
kwhizz kwhizz is offline
A couple updates...…. #1.... Took Welds advice and sent the original bench seat out to Tracey Weaver to work his magic to balance it out with contoured Foam and keeping the pattern looking some what stock to match...…
#2...… The intermittent clicking issue when trying to start the car ended up being a connection issue at the column mounted neutral safety switch
#3..... the Battery going dead ended up being in the aftermarket ignition switch included in the rewire kit...…… the original 57 Key bezel is still used..... It has Start...Run...off... and Lock on it...…..Unknown to me.... (Probably in the Instructions....LOL )when I would shut off the car and turn the key to the lock position...…. In the new switch it is actually in the Accessory position....When I looked under the dash while fixing the neutral safety switch I noticed that the Dakota Digital modules were lit up...… turn to the off position and everything went out and no more issues...….This Car stuff is Hard !!!!
The Following User Says Thank You to kwhizz For This Useful Post:
Xplantdad (12-10-2018)
