Old 04-14-2023, 10:43 PM
Pro Stock John's Avatar
Super Moderator
Default 1970.5 Camaro ID
Buddy is going to sell a roller in the next couple of weeks, 1970.5 Camaro.
Automatic car. All the parts are gone, not the original rear end. Van Nuys car. Tach redline is 6500, yellow starts before.
Any advice on what to look for to figure out if it could be a Z/28 or it's just an RS? Here are pics. He said the nose looks like it's been replaced. I also asked him for a better trim tag pic.
Here's what I got so far:
Attachments - The Supercar Registry 341486584_875232723545133_4911500382357871420_n.jpg 340238766_978491230228061_8043941291105713559_n.jpg
Old 04-15-2023, 01:38 AM
ronzz572 ronzz572 is offline
Vanuys 1970 camaros usually have the build sheet above the fuel tank drivers side. Also in the front seat covers usually passenger side seat. You mentioned the tachometer is a 6500 red line. Thats a L78 tachometer. If the tachometer is original to the car it may be a L78 camaro. I will message you my phone number. Give me a call and I can help you with more details?
1970 z28 4speed cranberry red white stripes standard saddle interior.
Old 04-15-2023, 02:28 AM
Super Moderator
I messaged you, please share your mobile and I'll get my buddy to reach out.
Old 04-15-2023, 02:44 AM
x77-69z28's Avatar
First tell tale sign is a floor mounted gas pedal.
Buddy
Old 04-15-2023, 05:02 AM
Super Moderator
My buddy and I talked about the gas pedal, those things can be swapped out. I'll see if I can go check the car out myself and take some pics.
Old 04-15-2023, 11:31 AM
Also look for welded on rear sway bar brackets on the rear frame rails. It being a original automatic body rules out L78. At the present time there have not been any automatic 70 L78 camaros proven made. As you mentioned. Parts are easily swapped. I would go for a build sheet. if the tank was never removed. It should be there.
The Following User Says Thank You to ronzz572 For This Useful Post:
DWR (04-16-2023)
Old 04-15-2023, 06:06 PM
Super Moderator
Original tank is gone. If there is a build seat in the passenger seat would it just be tucked in there? I'll ask him to check. He said auto car so we figured not an L78.
Old 04-15-2023, 06:10 PM
Super Moderator
Int 711
Paint 26
Build date 06E
Old 04-16-2023, 12:20 PM
L16pilot L16pilot is online now
The Z28 floor mounted gas pedal can be swapped out, but would leave the two 1/4" holes for the ball studs in the toe-board. Also, look for evidence of holes in the lower rear tail panel for the rear bumper fang mounts. Combined with the rear sway bar frame mounts and aluminum blocks under the LCA bumpers, it could give an indication of what the car might have been. Unfortunately, with the original driveline gone, no build sheet and being an LA car, there's just no smoking gun to ID what it was originally.
Steve Nuwer
1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored
1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project.
1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project
1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD)
www.2ndGenZ.com
The Following 2 Users Say Thank You to L16pilot For This Useful Post:
Pro Stock John (04-16-2023), SPEEDYB (04-17-2023)
Old 04-16-2023, 03:46 PM
If there's a chance the seats are original. I know of 2 1970 vanuys camaros with build sheets found in the upper passenger side seat upper back. They were front side between the padding and seat cover. One is a 70 L78 I personally own. And another posted on a forum and discussed. Hopefully maybe one is there. Just make sure if readable the vin matches the car upper right hand corner if you find one.
