Old 09-23-2020, 10:24 PM
Enoch Enoch is offline
70 through 74 Camaro Chevelle Nova Firebird Etc Delco Remy ignition points shield and mounting screws. Excellent restored condition of assembly line installed pieces. $35. Ppff
Old 09-26-2020, 12:15 AM
Excellent restored set of original front a arm alignment shims. $50. Ppff 3 sets available.
************SOLD************
Old 09-26-2020, 12:32 AM
Perfect excellent original assembly line restored big block axle caps. These have been stripped they have been replated zinc and phosphate added on top of it so they will never rust. $45 a set of four. Three sets available. Ppff
Old 09-26-2020, 12:41 AM
68 small block rear engine lift brackets. One with K stamping and one with CM stamping. Both are in mint condition. They've been stripped and zinc-plated. As nice as you are going to find. $25 each. Ppff
Old 09-26-2020, 12:53 AM
100% original untouched unrestored Survivor 69 through 77 Corvette 4 speed transmission interlock cable. Still has yellow inspection ink on top end. As nice and original as you're going to find that works perfectly. $75 plus shipping. Ppff
Old 09-26-2020, 01:06 AM
Excellent restored small block rear crankcase breather and rbw head marking mounting bolt. Also included is the original seal and flat washer. Absolutely perfect condition. $35. Ppff
Old 09-26-2020, 01:40 AM
Original unrestored 1963 Corvette power brake hose to valve cover support with C stamp. Very nice original unrestored piece. $50. Ppff ************SOLD************
Old 09-26-2020, 01:43 AM
Excellent original unrestored unpitted small block spark plug heat shield does not have support bracket but it's nice and original as you're going to find with original stamping. $35. Ppff
Old 09-26-2020, 01:47 AM
Excellent restored original SS stamped small block solenoid Shield. $30. Ppff
Old 09-26-2020, 01:51 AM
Very nice original unrestored Quadrajet 2 carburetor accelerator return spring bracket. Left it dirty greasy grimy for a Survivor but he's in Perfect Pitch recondition and we'll clean up beautifully. $35. Ppff
