Old 01-15-2022, 08:08 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
Default Rear Sway Bar Question
Mocking up a Nova rear sway bar from various parts.
-one NOS sway bar spring perch
-one modded (was NOS) sway bar spring perch. (ran on the mini tubbed Nova for a few years... will rework back to stock configuration)
-several bars all the same
-two different styles of uprights
QUESTION IS;
Which uprights would be correct for 71-72 Nova ??
Lower clam shell straight down or 90 degrees
The 90 degree uprights have a little dog leg offset to them.
All dimensions check out
-center pins 43" (matches the diff)
uprights approx. 25-1/2 centers (matches the body)
Name:  Sway Bar Mock up 01.jpg
Name:  Sway bar Mock up 02.jpg
Name:  Sway bar upright 01.jpg
Name:  Sway bar upright 02.jpg
Name:  Sway Bar upright 03.jpg
Name:  Sway bar upright 04.jpg
Name:  Sway bar upright 05.jpg
Thanks for any input guys !
Gary
70 Chevelle SS-454 LS-5 M-22
Attachments - The Supercar Registry Sway bar upright 05.jpg Sway bar upright 04.jpg Sway Bar upright 03.jpg Sway bar upright 02.jpg
Old 01-15-2022, 08:39 PM
Canuck's Avatar
Canuck Canuck is offline
I have a 1978 Nova 9C1. I will check dimensions.
www.vancouverclassiccars.com
Old 01-15-2022, 10:47 PM
L78_Nova's Avatar
Thanks but 75 up is different...wider.
I just need to know what uprights are correct. My dimensions have been verified against the diff and body.
Gary
Old 01-16-2022, 03:14 AM
nuts4novas nuts4novas is offline
Gary: The 90 degree end uprights are correct for 72-75 Nova. Part numbers are 3998667 and 3998668 , Group 7.242 Same as on my 72 Nova.
John
The Following User Says Thank You to nuts4novas For This Useful Post:
L78_Nova (01-16-2022)
Old 01-16-2022, 01:46 PM
Gary, the slight bend at the bottom of uprights is correct for 72 Nova, mine has it.
L78_Nova (01-24-2022)
