#31
Wow looks great! Keep it up.You're giving me ideas.
https://www.youtube.com/watch?v=gkDf7PPRzJ0 |
The Following User Says Thank You to BJCHEV396 For This Useful Post: | ||
RPOLS3 (05-23-2021) |
#32
Rainy Sunday morning here yesterday so I spent some time back on the Chevelle. Still waiting for the fuel pump - will be a couple more weeks I guess.
Last week I was able to get the rear brake cylinders assembled and installed. My plan for yesterday was to install a new rear flexible brake line and bleed the brakes. I bought an AC Delco line rather than a repop figuring I wouldn't have any issues - but guess what...the hole for the attaching bolt wasn't machined big enough. I should have known when I saw the Made in China on the box.... I hooked the old line back up and started to bleed the brakes, was able to get fluid to the back but for some reason I am not able to get fluid out of the front calipers........will need to diagnose that next. So it sits for a while longer now. |
The Following 7 Users Say Thank You to RPOLS3 For This Useful Post: | ||
dykstra (05-25-2021), markinnaples (05-25-2021), napa68 (05-26-2021), NorCam (05-30-2021), olredalert (05-27-2021), SS427 (05-26-2021), Xplantdad (05-24-2021) |
#33
Might want to try bench bleeding your master cylinder, since you had it all apart and reconditioned.
All the parts turned out great!!
Dave Dykstra 1968 Camaro Palomino Ivory/Ivy Gold interior -Delivered to Courtesy Chevrolet, Los Angeles, CA 2013 Corvette Grand Sport 60th Anniversary -Delivered to Bill Jacobs Chevrolet, Joliet, IL NCRS#66003 “Education is what you get when you read the fine print. Experience is what you get if you don’t.”-Pete Seeger Dykstra Motorsports |
The Following User Says Thank You to dykstra For This Useful Post: | ||
RPOLS3 (05-25-2021) |
#34
If you have the piston style proportioning valve, it may have tripped from pressurizing the rears and has cut off fluid to the front.
The Following User Says Thank You to Too Many Projects For This Useful Post: | ||
earntaz (05-26-2021) |
#35
Thanks |
#36
Ok. Good luck.
RPOLS3 (05-26-2021) |
#37
Jake,
I love the progress and the pics Thanks for sharing. Dan
69 300 Deluxe Post Sedan Frost Green 69 SS396 300 Deluxe Post Sedan Lemans Blue SOLD 70 Buick Skylark Post Sedan Gulfstream Blue 70 Buick Skylark Post Sedan Burnished Saddle http://m.youtube.com/watch?v=PM3DE8qI2NY https://m.youtube.com/watch?v=Yn4xEmGypUw |
The Following User Says Thank You to Postsedan For This Useful Post: | ||
#38
Re-centering tool won't work on my prop valve as the pressure switch does not appear to be removable from the valve while on the car. Getting fluid to the valve from the M/C but nothing out of the front port, so it has to be the valve being un-centered.......ugh. Tried compressed air into the front port multiple times to re-center it but no luck. Also tried tapping on the side with a hammer with no luck. Think I am going to have to remove the valve to try and disassemble it or send it out - but the rear brake line is not playing nice and does not want to come off, as it is the original to the car and I don't want to twist it. Soaking the sh*t out of it and letting it sit overnight. FUN!
#39
Crack open a bleeder on the rear and you should be able to push the plunger.
NorCam (05-30-2021) |
#40
Appreciate all the comments and suggestions. |
